Info On Double Lug Meter Socket - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2007, 05:20 PM   #1
Info on Double lug meter socket
needing info on maybe using a dbl lug meter socket to supply my detached garage.
house main panel is 200 amp. planning on useing 80 amp.or 100 amp main panel in garage. distants betwen the two will be about 80 feet.
would i need a 200 amp or a 320 amp dbl lug meter socket to do this?.
main panel in house needs replaced cause of the history of it (old sylvania :-( ). got a price of 650.00 to replace it.with a semans.
i have a milbank socket now 1978 model,any way of telling what it is without opening it up?
so what size dbl lug socket i need?
size wire for the distants?
and any additional info be helpful or better ideals
aokss is offline   Reply With Quote
Old 03-04-2007, 06:24 PM   #2
without a load calculation on the house and garage, the rest is just guessing.
If you do not know how to do these get a good book on residential wiriing and read that first, or hire someone to do the calculations for you.
Master Electrician
jwhite is offline   Reply With Quote
Old 03-06-2007, 05:59 PM   #3
wow.....thanks
turning gas on/off at the meter amakarevic Plumbing 17 04-23-2011 08:21 PM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 11:33 PM
meter to service panel mikim Electrical 5 05-04-2007 06:34 AM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 09:26 AM
socket broken andrea Electrical 1 07-05-2005 07:18 AM
