Industrial Wall Fan On Covered Porch - Not UL507 Rated Plugged Into GFI - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 06:52 PM   #1
Industrial wall fan on covered porch - not UL507 rated plugged into GFI
Hi,
I'm located in Phoenix, AZ.
I bought an industrial fan to which I'm attaching a misting ring on the front grill, so the fan will blow mist over the covered porch area. The fan will be plugged into a GFI outlet outside on the covered porch. After the fact I realized that the fan is not rated for outdoors (UL507).
Is this too risky, or will plugging into a GFI be OK?
Thanks,
Ove
OveMarkstrom is offline   Reply With Quote
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
HVAC duct through a fire rated wall elmaur Building & Construction 2 05-30-2011 01:22 PM
Foundation wall for covered porch turned sunroom robdville Building & Construction 4 01-23-2008 06:28 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
