Induction Cooktop Wiring Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 11:40 PM   #1
induction cooktop wiring requirements
Hi to all,
Need to compare wiring needs for ceran electric cooktop versus induction cooktop which may need heavier duty power, have under benchtop oven already on higher amp wire plugged in but want to ensure correct highest power for induction and oven running at the same time. May have to upgrade circuit breaker in box as no more space for further breakers. Thank you for any advice.
Busyas is offline   Reply With Quote
Old 10-12-2012, 12:59 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,942
Most induction cooktops use less power than regular cooktops, or at most the same power. You would need to look at the actual specifications for the cooktop you are buying to know for sure if your existing wiring is adequate.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-12-2012, 07:04 AM   #3
Induction cooktops
Thank you for your reply, still not sure if we should get the ceran electric or the induction cooktop, as we will not replace with a gas again.
Old 10-12-2012, 07:38 AM   #4
Rewards Points: 29
You will need an additional circuit for the cooktop. You can not share the circuit you have the oven connected to.
cube17576 is offline   Reply With Quote
Old 10-13-2012, 01:46 PM   #5
I didn't pick up on the details here: You had an electric oven with a gas cooktop, and want to replace the cooktop with electric by adding it to the oven circuit? You can't do that. You will need a separate circuit for the electric cooktop, no matter what type you choose. There are solutions to add circuits even if your panel is full. You may be able to use tandem or quad breakers, combine some small circuits to make room, or install a subpanel.
Electric cooktop wiring issues kbrookst Electrical 17 04-13-2012 01:36 PM
Freestanding range to cooktop + oven combo. Lots of data (kw, wiring, etc) made2last Electrical 12 04-07-2012 12:19 AM
240V 50HZ Induction Cooktop wiring in US NoelRC Electrical 4 02-17-2012 02:48 AM
Kitchen Wiring Requirements SS396 Electrical 24 02-07-2011 10:00 AM
Cooktop wiring code epudimott Electrical 3 07-19-2008 11:01 PM
