Old 12-31-2007, 11:22 AM   #1
Indoor wire vs outdoor wire
I need about 20 feet of wire for an outlet in the attic but have run out of wire. I do have plenty of outdoor wire (both 12/2 w/ground) that is left over from hooking up a porch fan. Is there any reason not to use this indoors?
Logic tells me that while I couldn't use the indoors outdoors I could use the outdoors indoors.
Potomac101
Potomac101 is offline   Reply With Quote
Old 12-31-2007, 11:30 AM   #2
Oldguy
Rehabber's Avatar
The outdoor wire will work fine, it's just harder to work with (and more expensive)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-31-2007, 04:00 PM   #3
Electrician philosopher
p,
Use the UF. A wire in your hand is less expensive than a wire at Home Depot.
Andy in ATL is offline   Reply With Quote
