Old 07-05-2011, 04:34 PM   #1
Question
indoor shed lighting
uhm.. what kind of lighting would you put in a shed that has exposed framing inside ?
thanks
Old 07-05-2011, 04:44 PM   #2
More info please.
What are you doing with the shed - is it just storage for the mower and lawn stuff, a workshop, or other? Do you need just enough light to find the shovel or rake - or light to work by? Size of shed? Ceiling height in shed? Do you want/need power outlets as well as lighting?
Do you have power to the shed now? If yes, a single 120v circuit, a subpanel, etc.? If no, what do you plan for getting power to the shed?
If no power to the shed, and need just enough light to find stuff - then one of the solar powered shed lights might be the way to go - reasonably priced, quick and easy to install.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
amakarevic (07-05-2011)
Old 07-05-2011, 05:19 PM   #3
Question
i have a 50A subpanel. it will have one circuit for the lights, one for outlets, and one for a rollup garage door.
the shed is 11x9 and i would like it to be well lit.
thanks
Old 07-05-2011, 05:25 PM   #4
Master Electrician
5 -400 watt lo-bays should work.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 07-05-2011, 05:29 PM   #5
Electrical Contractor
for an operating room!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 07-05-2011, 05:34 PM   #6
Master Electrician
It will be 'well lit'.
Old 07-05-2011, 05:56 PM   #7
Depending on your definition of well-lit, one or two 48" two bulb fluorescent shop light fixtures would do the job. For example one positioned over a work or workbench area, another for general lighting. A roll-up garage door limits positioning of lighting.
I have several such lights in my 24x30 workshop. The lighting circuit consists of switched outlets in the ceiling. A 1x4 is placed acrosss the ceiling joists to create a raceway for the wiring. The fluorescent shop lights plug into the switched outlets. Also plugged in are a couple work lights on retracting reels - very handy when needing concentrated light on the job at hand. Plus I have one light on a motion sensor - handy when exiting or just entering to grab a tool or gizmo and leaving out again.
Consider exterior lighting as well. I have a barn style light with LED bulb over the garage door on a dusk to dawn sensor and a flood light when lots of light is needed.
____________
Vince
amakarevic (07-06-2011)
Old 07-05-2011, 06:03 PM   #8
If it was my shed I would put up 2 or 3 2bulb 48" T8 fixtures. Don't bother going to HD to get their shop lights at $15-20, go to a good electrical supply house and pay the $40-50 for the good units if you plan on spending time in the shed with the lights burning away.
Plumbvoltage is offline   Reply With Quote
The Following User Says Thank You to Plumbvoltage For This Useful Post:
Old 07-05-2011, 07:07 PM   #9
Electrician
SD515's Avatar
It'll be a tanning booth
Kyle
Old 07-06-2011, 12:51 AM   #10
" Euro " electrician
frenchelectrican's Avatar
And the other thing if going to mount lower than 7 feet or less I know some sheds are pretty low so if you do use the flourscent lumiaires then I will suggest to buy a bulb sleeve to protect ya from shattering glass.
Otherwise there is a shatter sheild bulb { they are not cheap but it worth it } couple big box store may have them in stock otherwise electrical supply centre will have it on hand.
Merci,
Marc
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 04:12 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
