Indoor Safety Switch Between Meter And Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 09:15 PM   #1
Indoor Safety Switch Between Meter and Panel
Hi All, I own a two family house in Easton PA. The house is set up with three separate 100A services. All three panels are currently located in the basement. I do not intend on giving the tenants access to the basement. But at the same time, I don't need to be making trips to the house at all hours because they tripped a breaker. I would like to move each panel servicing the apartments into the apartments and install a safety switch (like this one) in the basement for each. I understand that there are options like a meter main, but I haven't seen any that seem all that secure-able. I would like a bit more control over the switch considering the fact that I might be working on the system and don't need some jerkoff throwing the switch and lighting me up. Would there be any issues with installing a non-fusible safety switch between the pan and panel? Any considerations I should keep in mind? Thank you!
silvajus is offline   Reply With Quote
Old 01-29-2012, 09:29 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Youll normally be required to install an outdoor disconnect from the meter
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-29-2012, 09:32 PM   #3
Licensed electrician
Rewards Points: 1,020
The new apartment panels would now need a 4 wire feeder from the disconnects and have to have all the neutrals isolated from the grounding conductors.
Old 01-29-2012, 09:32 PM   #4
Master Electrician
Rewards Points: 3,678
It definitely could NOT be an unfused disconnect, and you will need four conductors to the apartment panels.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
plummen (01-29-2012)
Old 01-29-2012, 09:33 PM   #5
Julius793's Avatar
I think the unfused part is also an issue.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-30-2012, 08:46 AM   #6
OK. So I still don't like the idea of a breakered meter pan for reasons of safety/security. I understand that the service must be fused at the nearest possible point after entry into the building (please correct me if I'm wrong). Would it be acceptable to install an enclosed main breaker (like this one) or a fused safety switch in place of the current panels and run the 4 wire feeder to the panels (at this point sub-panels) in each of the apartments?
Thanks!
Tags
electical , meter main , panel , safety switch
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
Upgrading Service/Moving Panel TheAcademician Electrical 17 09-13-2011 08:48 PM
Does it matter how close your panel is to your meter? jamiedolan Electrical 10 10-18-2008 05:38 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
New meter panel tomreva Electrical 3 01-08-2008 04:56 PM
