Incandescent And Fluorescent Together - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2008, 03:26 PM   #1
Incandescent and fluorescent together
Hi,
I was just cleaning the basement and found I have 3 incandescent cans laying around and thought I'd install them to give me more light in the basement. The circuit I want to hook them to (because of the switch) has one hard wired and two plug in (to outlets) fluorescent lamps.
My question is, is it ok to install incandescent and fluorescent fixtures on the same circuit?
Thanks, Bill
Big Bill is offline   Reply With Quote
Old 11-01-2008, 03:39 PM   #2
dSilanskas's Avatar
Originally Posted by Big Bill View Post
Hi,
Thanks, Bill
Not a problem
dSilanskas is offline   Reply With Quote
Old 11-01-2008, 04:37 PM   #3
Thanks dSilanskas,
One more question....
It should be OK to run the feed for those cans from an outlet? There is an outlet at the end of the run, so I was going to attach the feed for the cans to the 'open' terminals on that outlet. Or do I have to remove the outlet and just that box as a junction box?
Thanks again, Bill
l
Old 11-01-2008, 04:40 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you can use that circuit if you want. I hesitate to put lighting on a general power circuit. If the circuit were overloaded by some use, it would put you in the dark.
If you use this circuit, I also would not run it through the recep. Pigtail out the wires. In some cases it would be illegal but aside from that, it is just better practice.
Old 11-01-2008, 05:20 PM   #5
Thanks nap,
The outlet was installed so the 'plug in' fluorescent (the kind you get at HD) could be installed.
I don't want to break any code.
Why would it might be illegal? Isn't pigtailed outlets better? If one outlet goes out, the others still work.
Thanks Bill
Old 11-01-2008, 05:31 PM   #6
nap
You talking to me?
nap's Avatar
Thanks nap,
Thanks Bill
are you plugging in a luminaire` (that is code speak for lighting fixture)? or hardwiring it?
I'm really trying to think of the sitatuation where fedding the power through the recep is against code. I can't seem to think of it other than the possibility of on a multiwire branch circuit where 2 hots use one neutral cannot depend on a device for the connection so pigtailing is a must.
Pigtailing is just better (IMO). Personally I never feed through a recep.
Old 11-01-2008, 05:49 PM   #7
Thanks for explaining nap,
Hardwiring it.
..... the possibility of on a multiwire branch circuit where 2 hots use one neutral cannot depend on a device for the connection so pigtailing is a must.
Nothing like that. All the branch circuits are the same as the feed. 12/2, nothing that complicated ....
As long as connecting incandescent and fluorescent fixtures on the same circuit is cool, then I'll just remove the outlet from the circuit.
Thanks, Bill
Kitchen outlet/switch dillemma? Need help troubleshooting lyonrt Electrical 6 02-13-2008 09:18 AM
Compact Fluorescent Lighting? kcrossley2 Electrical 2 07-23-2007 10:18 PM
New recessed light is killing bulbs nebben Electrical 2 02-03-2007 09:33 AM
