I'm Puzzled... 3 Way Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 10:23 AM   #1
I'm puzzled... 3 way light switch
One of my 3 way light switches wan't working properly. One switch would have to be "on" for the other to work. I took them both out and realized the common switch had a white wire in one and a black in the other. I made it so they were the same but it's still not working properly.
Any ideas?
cyras21 is offline   Reply With Quote
Old 09-02-2012, 10:30 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
We need to know all wires in each of the two boxes (pictures would help).
Old 09-02-2012, 10:31 AM   #3
Rewards Points: 216
see this for wiring 3 way switch
http://www.homeimprovementweb.com/in...way-switch.htm
and compare with your setup. This may clarify your issue.
orange is offline   Reply With Quote
Old 09-02-2012, 12:03 PM   #4
An electrical tester would be very helpful.... at the least, let us know which wire colors are where. You never know if the electrician actually used the same wire colors in both locations like he/she was supposed to.
idlplumb is offline   Reply With Quote
Old 09-02-2012, 01:04 PM   #5
got it...thanks
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Mystery Light Switch smokey847 Electrical 3 02-04-2012 10:44 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
