I'm Having Trouble Replacing A Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2010, 11:41 AM   #1
I'm having trouble replacing a wall switch
I'm trying to replace a standard single wall switch with an electronic timer switch. The switch turns on a bathroom fan.
**Currently there are two black wires from the wall that connect to the single wall switch.
**My new timer switch has four different colored wires. It tells me to connect the red and black wires to the red and black wires in the wall, however BOTH wires from the wall are black.
**So how do I connect this? I want to connect the red wire from the new switch to the correct wire from the wall.
Thanks,
James
jamesjames is offline   Reply With Quote
Old 03-13-2010, 11:46 AM   #2
Master Electrician
Rewards Points: 3,916
Thanks,
James
One of the black wires in the wall is the line and the other is the load. The line is the power coming in when the breaker/fuse is on. The load takes the power through the switch to the fan. Line and load should be on the timer or in the instructions. White goes to the whites in the switch box. Green goes to the bare or green grounding wires in the switch box. If there are no white(neutrals in the switch box then the electronic timer will not work and you will have to use a mechanical (springwound) timer.
brric is online now   Reply With Quote
Old 03-13-2010, 11:59 AM   #3
How do I determine which wire is the load and which is the line? They are both black wires...and I need to connect them to the red and black wire on the switch.
Old 03-13-2010, 12:32 PM   #4
Master Electrician
Is one of the black wires wire nutted to several other? That is probably the line. Should be checked with a voltmeter.
Old 03-13-2010, 03:27 PM   #5
Electrician
Rewards Points: 800
trial and error if you don't have a meter. Try it one way and then flip the wires if it doesn't work.
Do you have a model number for the timer then we may be able to look at the instructions and give you a more detail answer.
darren is offline   Reply With Quote
Old 03-13-2010, 03:54 PM   #6
Rewards Points: 342
This is likely a switch loop, so you don't have a neutral. You may have to find a timer that does not require a neutral.
tribe_fan is offline   Reply With Quote
Old 03-14-2010, 01:44 AM   #7
Both black wires appear to be coming out of the wall. There is a white wire that is bundles up into itself in the wall.
Can there be any harm in trying it one way to see if it works? Would I risk damage to the circuit breaker or anything else if I got it wrong?
Tags
bathroom fan switch
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Replacing wall light. schnitz411 Electrical 5 04-28-2009 05:36 PM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 08:13 AM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
