I'm Confused About Ground Wire Coloring. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 02:18 AM   #1
CareBear
Question
I'm confused about ground wire coloring.
I looked at the NEC 2014 draft, section 200.6 and it says that grounded conductors should have either a gray or white finish. Yet all over the Internet it says ground wires are green, plus ground screws for appliances are green.
CareBear is offline   Reply With Quote
Old 02-01-2013, 03:33 AM   #2
Licensed electrician
Rewards Points: 1,506
You are confusing grounded with grounding conductors. Grounded are the neutrals.
Old 02-01-2013, 05:28 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
This is one of the reasons why lay people should not simply pick up the NEC and start reading. You need some primer to get a feel for it first.
Some serious mistakes can be make otherwise.
Old 02-01-2013, 07:10 AM   #4
Resi EC
Rewards Points: 252
There are 3 grounds used in electrical work.
Ground - Earth
Grounded - Neutral, White or grey in color
Grounding - Conductor, Bare or green in color
In most transformers or main disconnecting means the Grounding takes the Grounded to Ground.
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
mpoulton (02-01-2013)
Old 02-01-2013, 02:45 PM   #5
CareBear
Most of the NEC is understandable, and I have some clue about electricity, so I'm not entirely lost reading the NEC. Gotta start somewhere, and the Sunset diy electrical book doesn't seem to be it.
Old 02-01-2013, 02:53 PM   #6
Rewards Points: 6,652
*Cough* Mike Holt website. I have found the Black & Decker Complete home wiring guide to be the best. Also if you can still find it out on the web, the U.S. Army basic electrical manual is good.
I may have it in my box.com account, or on my pocket drive.
Tags
color , gray , green , ground , wires
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Light switch - Taping into ground wire ok? SimpleJack Electrical 2 08-15-2011 07:04 AM
What do I do with the ground wire? Letty Electrical 1 03-17-2011 12:47 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
