-   -   I'm confused about ground wire coloring. (http://www.diychatroom.com/f18/im-confused-about-ground-wire-coloring-170719/)
CareBear 02-01-2013 02:18 AM
I looked at the NEC 2014 draft, section 200.6 and it says that grounded conductors should have either a gray or white finish. Yet all over the Internet it says ground wires are green, plus ground screws for appliances are green.
Jim Port 02-01-2013 03:33 AM
You are confusing grounded with grounding conductors. Grounded are the neutrals.
Speedy Petey 02-01-2013 05:28 AM
This is one of the reasons why lay people should not simply pick up the NEC and start reading. You need some primer to get a feel for it first.
Some serious mistakes can be make otherwise.
Gac66610 02-01-2013 07:10 AM
There are 3 grounds used in electrical work.
Ground - Earth
Grounded - Neutral, White or grey in color
Grounding - Conductor, Bare or green in color
In most transformers or main disconnecting means the Grounding takes the Grounded to Ground.
CareBear 02-01-2013 02:45 PM
Most of the NEC is understandable, and I have some clue about electricity, so I'm not entirely lost reading the NEC. Gotta start somewhere, and the Sunset diy electrical book doesn't seem to be it.
gregzoll 02-01-2013 02:53 PM
*Cough* Mike Holt website. I have found the Black & Decker Complete home wiring guide to be the best. Also if you can still find it out on the web, the U.S. Army basic electrical manual is good.
I may have it in my box.com account, or on my pocket drive.
