Illuminating A Driveway - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 06:22 AM   #16
Rewards Points: 756
Originally Posted by dmxtothemax View Post
1- If theres 150w at the secondary, then there must be at least 150w at the primary. (actually a little more at primary, to allow for losses).
2 - dc is NOT harder to push thru cable, when compared to ac.
The same rule applies for ac and dc.
And the losses will be the same.
You can always put some extra volts in, if the run is long
and losses are significant.
Not true. There is more resistance to AC current due to the skin effect that causes current to travel primarily towards the surface of the wire.
Mark
busman is offline   Reply With Quote
Old 04-12-2012, 08:24 PM   #17
dmxtothemax's Avatar
Rewards Points: 5,490
In a system like this IE "60Hz" the losses due to skin effect,
would be so small, it would not even be worth worring about !
It is only significant at much higher frequencies like RF.
dmxtothemax is online now   Reply With Quote
Tags
floodlight , led , low , voltage
Driveway + Walkway buildup question r0yal Landscaping & Lawn Care 2 03-24-2012 08:42 AM
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 11:50 AM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 03:42 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
