Illuminated Switch ??? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2011, 03:25 PM   #1
Illuminated switch ???
I would appreciate any guidance on this please.
I just changed out a dimmer switch to a regular "illuminated" switch. When I turn the switch "on", the light in the switch goes off, and the overhead lights go on. That is the way it is suppose to work anyway.
Here is my problem, I can not keep the illuminated switch to stay on when I put pressure on it...i.e. screwing the switch in to the box. When I do, the "illumination" goes out. Otherwise, the switch works fine. The overhead lights work, no problems. If this switch were not "illuminated", there would be no problem. I know the "illuminated" switch is only active when the wall switch itself is turned off. If I loosen the screws on the switch to the box, the light comes back on. When I tighten the screws, it goes off.
Any ideas ? I was thinking either a short or a defective switch (?) I took it apart 3 times, and made sure all the wiring looked okay.
Thanks in advance,
dave95sps is offline   Reply With Quote
Old 05-28-2011, 03:44 PM   #2
Rewards Points: 1,506
I say that the switch itself is defective.
An illuminated switch has just the same two terminals that you connect up the wires to the light or other device being controlled by the switch. If those connections were loose then the device being controlled would not work.
Old 05-28-2011, 04:44 PM   #3
Electrical Contractor
kbsparky's Avatar
Bad switch. Try another one.
-KB
Old 05-29-2011, 07:06 AM   #4
Thanks guys ! Sure do appreciate your responses. This gives me one more reason to visit Home Depot !
Old 05-29-2011, 01:44 PM   #5
Scared Electrician
Saturday Cowboy's Avatar
Who needs a reason to visit my favorite store????
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-29-2011, 05:11 PM   #6
Tags
illuminated , switch problem
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
