Illuminated Paddle Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 08:47 AM   #1
Illuminated paddle switch
I have been replacing several switches in the house with illuminated switches with no problems - all work and illuminate. I have one single pole switch that works but will not illuminate, it controls a wall outlet. I've tried the switch in another location and it illuminated. I also replaced it with another that resullted in the same problem... I've even switched the common during hook up to see if it made a difference - Switch did not work at all. Does anyone have a solution?
bulldog66 is offline   Reply With Quote
Old 10-22-2008, 12:20 PM   #2
Rewards Points: 508
Send a message via AIM to theatretch85
Is it supposed to light up when the circuit is off (so you can see it in the dark) or when the circuit is on? Most lighted switches are the first, that is they light up only when the circuit is off. If this is the case of your switch, try plugging in a lamp to the outlet and make sure the lamp is on. The lighted switch needs a load connected to it in order for the indicator to light up.
If the switch is supposed to light up when the circuit is on, its possible there is a bad or missing neutral wire to the switch itself.
theatretch85 is offline   Reply With Quote
Old 10-22-2008, 03:13 PM   #3
Thanks for your input. Your diagnosis was correct.... Keep up the good work.
3-way illuminated switch - voltage present ktulu05 Electrical 18 11-29-2009 04:01 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
