Illuminated Light Switch Causing A Flash - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 07:29 PM   #1
Rewards Points: 150
Illuminated light switch causing a flash
Replaced two 3-way residential light switches with two illuminated ones that work one ceiling light fixture containing a compact fluorescent bulb. Now on occasion I get slight 'flash' from the bulb with all switches off and in the dark. Any idea what can be causing this? I then replaced the compact fluorescent with an incandescent bulb, and it no longer flashes. But If I switch back to a compact fluorescent bulb, the occasional flash returns. Any theories?
bernieb is offline   Reply With Quote
Old 02-16-2011, 08:42 PM   #2
The illuminated switches are not totally "off" when the switch is in the off position. That is how they are able to light the internal bulb with the switch in the off position. Apparently CFL's are more sensitive to this small flow of electricity and hence your flickering. You probably need to decide between the illuminated switches and incandescent bulbs or normal switches and CFL's.
clydesdale is offline   Reply With Quote
Old 02-16-2011, 09:04 PM   #3
joed's Avatar
Rewards Points: 12,440
Lighted when off switches flow a tiny amount of current through the bulbs to light the switch. This tiny current makes CFLs flicker. One incandescent bulb on the circuit is usually enough to stop the flickering.
Old 02-17-2011, 06:43 AM   #4
Rewards Points: 150
Thank you for the response, and nice to know what causes the flash, but have gone back to the incandescent bulb.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Light controlled by switch, outlet always on, power at light...is this the way? pureevil Electrical 6 11-07-2010 05:32 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
