Is This Illegal Or Just Poor Workmanship? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 08:05 PM   #1
Is this Illegal or just poor workmanship?
I go by this house everyday. One day I noticed something didn't look right, the SE wires were kind of low. They are mounted on the side of the house about at the top of the first story windows (7-8 ft.) in the front corner. The worst part is their is a farmers porch on the front and any average height person could stand on the porch and be able to reach out and touch the wires.
Plumbvoltage is offline   Reply With Quote
Old 02-28-2009, 08:08 PM   #2
My old house was in a former cottage area
All of the SE feeds were low
I was actually able to raise mine up about 12"
But other houses were "stuck" unless the wire was replaced
Since the POCO owns the wire they usually will not replace it without goods reason
Take a pic & post it
Old 03-01-2009, 03:59 AM   #3
Rewards Points: 1,192
Why would you want to????
bobelectric is offline   Reply With Quote
Old 03-01-2009, 07:23 AM   #4
Remodeling Contractor
To see if the electric is leaking of course.
Old 03-01-2009, 08:28 AM   #5
Some people may want to be a darwin award winner!!
It just doesn't seem right to have those wires and connections so close to a persons access. I would have thought they would have mounted a little higher or just farther from the porch.
Old 03-01-2009, 08:40 AM   #6
maybe a home owner built the porch (without permit of course)
Old 03-01-2009, 10:59 AM   #7
Rewards Points: 240
Your concern is valid. The SE conductors and weatherhead must be at least 10' above grade.
Old 03-01-2009, 11:17 AM   #8
Rewards Points: 344
I certainly no expert - and I'm not going to get into a debate about grandfathered vrs. new installation, but I thought the Mast had to be a minimum height ?
http://www.duke-energy.com/pdfs/RB300.pdf
Sounds like an accident waiting to happen.
Last edited by tribe_fan; 03-01-2009 at 11:19 AM. Reason: J.V. Posted while I was typing -
tribe_fan is offline   Reply With Quote
Old 03-01-2009, 02:54 PM   #9
Where i live the service entry fitting must be 13' above grade!
Where i used to live, my neighbors SE hung so low that the road-grader caught it! The PA had to install a pole, to get it up higher. Funny part was that they hit the water main when they augered the hole! Ended up with half the road dug up.
Illegal construction; How will building department react? limey510 Building & Construction 4 02-23-2009 04:25 PM
recessing a beam needa Building & Construction 12 12-26-2008 10:29 AM
mold problem, illegal? elementx440 Remodeling 6 04-09-2007 06:41 PM
