IKEA Ceiling Light Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 09:41 PM   #1
Lou
Question
Hello,
So... For the life of me I am unable to install this ceiling light I bought from Ikea.
Coming out of the Ikea light are four wires... 1 black, 1 white, 1 teal, 1 green/yellow (assuming the ground).
Coming from the ceiling is 1 black, 1 white, 1 teal, and 1 yellow.
I feel like I've tried almost every combination and the light still will not work.
Any help is appreciated.
Thanks in advance
onemorelouis is offline   Reply With Quote
Old 03-05-2013, 09:51 PM   #2
Pure Genius
Rewards Points: 150
What do the instructions say? How was the old fixture installed?
Dierte is offline   Reply With Quote
Old 03-05-2013, 09:52 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Pics help.
I have never seen a teal colored wire coming from the ceiling, and I hate Ikea lights!
Old 03-05-2013, 09:52 PM   #4
Rewards Points: 13,450
#1 Go back and add your location to your profile, you can just go up to Quick Links and edit it.
Sure sounds like your not in the US with that color code.
How was the old light wired?
Old 03-05-2013, 09:59 PM   #5
Lou
They're ridiculous
I live in a condo in Toronto, Ontario
There was no fixture here previously...but there is power, I checked...
There's also power going to the ballast but there is no light, and I've tried using two different bulbs...
Do you see the pics?
Old 03-05-2013, 10:03 PM   #6
Lou
Here's another...
Old 03-05-2013, 10:36 PM   #7
Lou
when I use the voltage meter on the wires coming from the ceiling, it only beeps on the yellow wire if that helps... Nothing happens when passed over the other three wires...
Old 03-05-2013, 11:50 PM   #8
Lou
the instruction manual says to twist the g/y + teal on the fixture to the round in the ceiling but how do I tell which colour wire is the ground in the ceiling?
Next... Connect black wire to black wire
Next... Connect white wire with white wire...
That's it...
The fixture came with one of those brackets that includes a grounding screw but nothing in the instructions indicate to use this screw with any of the wires...
Old 03-06-2013, 06:30 AM   #9
jbfan's Avatar
Rewards Points: 386
Green
That's it...
How many switches are thee for this light fixture.
You need a meter to test the wiring, cause a tic tester will not be accurate with that many wires.
Try wiring it the way the instruction say, and cap off the yellow wire in the ceiling.
Old 03-06-2013, 12:03 PM   #10
Lou
These are the wires coming from the ceiling... There's also 2 braided black wires capped off...
Old 03-06-2013, 12:10 PM   #11
Lou
Here is a picture of the fixture...
When I connect yellow ceiling wire to black lamp wire, I use the volt meter and power will run through the lamp but won't light...
I tried the way the instructions say... Teal lamp wire + y/g lamp wire to teal wire in ceiling, black to black, white to white, but this didn't work... When I used voltage meter around lamp, there were no beeps...
I took off the light switch panel... On the switch... The black wire is in the bottom, and the yellow wire through the top...
Anyone recommend anything else??
Old 03-06-2013, 12:12 PM   #12
Lou
Old 03-06-2013, 12:14 PM   #13
Lou
Light switch
Old 03-06-2013, 12:36 PM   #14
Rewards Points: 321
I have an idea. Go back to basics. Find an incandescent fixture of any kind and work with it to find the combination. Ballasts can be bad right out of the box, as can fluorescent lamps. Make sure you know the light bulb is good. Go to town. If you can't get an incandescent bulb to light, it's time to methodically dig into the circuit.
If you must troubleshoot the circuit, use a real meter, not a proximity tester. Start at the switch for power, then move to the other side of the switch when on/off (switches go bad too). Then move on up the line to the ceiling.
You'll find it in due time. Just use patience and logic.
Is that a three way switch? Does it have three screws?
al_smelter is offline   Reply With Quote
5000k Light Blulbs for Ceiling Fan Fixture (clean white light for living room) cmf0106 Electrical 10 01-12-2012 10:04 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 08:32 AM
Help- cant get a new ceiling fan light to work boddabing Electrical 6 08-26-2010 05:24 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 10:30 AM
