-   -   If power adapter has a polarity symbol, is it AC-DC? (http://www.diychatroom.com/f18/if-power-adapter-has-polarity-symbol-ac-dc-165350/)
bugmenot 12-02-2012 10:01 AM
I need a 9V ~780mA AC to AC adapter with a 1/8" TS plug. My friend passed me one, but it has a polarity symbol on it, does that mean it is AC to DC? From what I understand polarity is not an issue with an AC to AC adapter. Thanks very much!
gregzoll 12-02-2012 10:30 AM
Post a picture. If it looks like a lazy S on its side, it is AC. If it looks like Morse code (Line with two or three dots above), it is DC for the output.
bugmenot 12-03-2012 11:31 PM
Pic: http://i.imgur.com/QeNo9.jpg
I suspect DC based on your info. I had tried it on the device in question when he gave it, and it didn't work. I assume no damage would have been done, as it was looking for AC not DC? Thanks!
frenchelectrican 12-04-2012 12:35 AM
The one you posted in the photo that is DC secondary supply.
My simple thumb of rules always replace with the same size or larger as the oringal one is.
And pay attetion to the connection on the plug espcally if the device required DC supply.
Merci,
Marc
Dave632 12-04-2012 09:41 AM
The tilde ( ~ ) after the Input: 100-120 means AC (a single cycle of a sine wave looks like the tilde symbol).
The Output is 9.0V DC at up to 1.0 Amperes. The straight line with 3 dots below indicates DC. Below that, the diagram indicates that the positive side of the DC goes to the center pin of the output connector, and the negative side goes to the outer (sleeve) part of the output connector.
concretemasonry 12-04-2012 10:08 AM
That is certainly a lot of information on a small space! All you need is the ability to determine what the symbols mean.
It will help me out to sort the mess of adapters I have collected over the years of traveling and having to buy adapters in a foreign country.
Dick
bugmenot 12-04-2012 09:49 PM
Merci,
Marc
First part, referring to mA right? Indeed, same polarity. That I know.
Thanks. So, if it were AC to AC, instead of the lines and dots it would be another tilde?
Dave632 12-05-2012 12:35 AM
Correct.
