If My House Is On Wooden Stilts I Dont Need GFCI Right - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 03:56 AM   #1
If my house is on wooden stilts I dont need GFCI right
since my house is lifted off the ground with wood stilts, GFCI is useless right? makes sense to me I'm sure NEC's opinion would differ these days tho.
bluemoonshine is offline   Reply With Quote
Old 03-20-2011, 04:04 AM   #2
infact the entire ground conductor system is pointless for a house like this right? wouldn't it add to the risk by providing a ground? lol
Old 03-20-2011, 04:52 AM   #3
Scared Electrician
Saturday Cowboy's Avatar
NO! You still need Ground Fault protection
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-20-2011, 07:38 AM   #4
the Musigician
DangerMouse's Avatar
Does mine?
DM
Old 03-20-2011, 07:46 AM   #5
DIY staff
Rewards Points: 7,174
Wooden shoes were popular in Holland 200 years ago----ancient records revealed that there were no electrocution deaths in Dutch houses during the 1700s.
Old 03-20-2011, 08:01 AM   #6
Pretending to be Retired
True, oh how true that was, but....what about termites issues?
BigD9 is offline   Reply With Quote
Old 03-20-2011, 08:06 AM   #7
DIY staff
They simply stomped on them.
Old 03-20-2011, 08:07 AM   #8
the Musigician
Ancient records also reveal no termites were electrocuted in Dutch houses during the 1700s.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
oh'mike (03-20-2011)
Old 03-20-2011, 11:27 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
Me thinks he drinks too much of his namesake or he is a troll trying to get a rise out of us
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 03-20-2011, 11:30 AM   #10
Rewards Points: 58
You are joking right? What makes you think this? Where do expect ground faults to go? They gotta go somewhere. If you do not provide this path, you just might become the path yourself. Of course this can happen in any house.
GFCI's do not require a grounding conductor to work. They do require a grounded conductor to work. So yes, you would need GFCI protection just the same as any other structure.
Old 03-20-2011, 08:27 PM   #11
I=E/R
a7ecorsair's Avatar
Originally Posted by DangerMouse View Post
Does mine?
DM
Nope, the NEC doesn't apply to total solar power in isolate atmosphere. You also don't need a GEC BTW, you didn't say which country your house was over
a7ecorsair is offline   Reply With Quote
Old 03-20-2011, 08:29 PM   #12
I=E/R
a7ecorsair's Avatar
And why do you feel this is true? Were you exempt from a grounding electrode
Old 03-21-2011, 01:42 AM   #13
lol.. my house has a fine ground system, I didn't know gfci's worked without the ground but that does make sence. I guess if the GFCI failed it's still better to get electrocuted from the hand through leg to ground and hopefully miss vitals, rather than hand to hand and through the heart.
Ofcourse I still use the ground.. I tend to go a bit overboard with safety usually. I'm actually thinking about putting my whole workshop on a 50amp GFCI to the subpanel, but a little worried about nusiance tripping with the fridge and everything its like a small house too
Old 03-21-2011, 10:57 AM   #14
Licensed electrician
Electrocution means death from electric shock. Would it really matter the path it took? Either route would have the same result if you were electorcuted.
Old 03-21-2011, 11:16 AM   #15
Rewards Points: 58
Putting a shop on a 50 amp GFCI breaker would be a waste of money, when you could install a sub panel with a standard breaker and use GFCI's as required by code.
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
dealing with exterior slope towards house. organick Building & Construction 26 03-19-2011 03:57 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Old wooden supports in basement of 2 family 100+ year old house ytorrie Building & Construction 2 06-03-2008 07:31 PM
