If I Were Going To - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 08:59 AM   #1
An old Tradesmen
Rewards Points: 7,760
If I were going to
run a line(10-3 UF) above ground from a house to a garage a distance of rough;y 95 foot.And sink 2-4X4s at equal distances. What is the better way to fasten/support the wire to.from the 4X4s?
Old 01-15-2011, 09:22 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Is this temporary? Personally I would NOT do it this way permanently.
To secure to the posts you should screw in some porcelain lag insulators and lash the cable to them using something like pieces of #10 solid. I would not wrap the cable around the insulator. Just pass it through the opening and secure it with the piece of wire.
Old 01-15-2011, 09:26 AM   #3
An old Tradesmen
Thanks. Its not my idea to be above ground. The guy doesn't want to wait for the ground to thaw. And wants my help. I said I'd check on it.
He needs some electric to have lights to work with.
Old 01-15-2011, 09:26 AM   #4
Rewards Points: 756
I agree with Pete. I'd bury it or use quadriplex on 6x6 posts. If you want to do it your way, check article 225 and the one in the 300's on Messenger Supported Wiring (sorry don't have code book handy).
Mark
busman is offline   Reply With Quote
Old 01-15-2011, 10:22 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Digging the post holes will be no fun in the frozen ground. If this is truly temporary until the ground thaws enough to trench; why not lay PVC conduit on the ground and pull in THWN wire? After trenching you could pull out the the THWN, bury the same conduit and reuse the THWN.
I assume the 10-3 UF you were planning on using is only temporary as that would only allow a 30 amp sub-panel.
Coastal South Carolina
Old 01-15-2011, 11:11 AM   #6
Rewards Points: 6,652
Electric thawing blanket would work in thawing, or very sharp shovel and a whole lot of cussing.
Old 01-15-2011, 12:54 PM   #7
Electrical Supplier
Rewards Points: 150
Its not up to code so as long as you arent getting it inspected you are fine.
UF is not rated for overhead drops(UF=Underground Feeder aka direct burial), you need to use quadruplex. Second, you must meet a minimum distance above ground for what the area below is being used for.
as far as fastening it, I would just use some Romex staples 1.25 inchers or so........Its not safe either way might as well do it cheap.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-15-2011, 12:57 PM   #8
Not to drift off topic, but this thread brings this to light:
Downed power line kills 3 in San Bernardino
A father died while investigating why the 12,000-volt line fell in the backyard and his wife and her son were killed when they tried to help.
http://www.latimes.com/news/local/la...,5748631.story
Old 01-15-2011, 01:00 PM   #9
Electrical Supplier
Rewards Points: 150
Uninsulated conductors FTW!
Old 01-15-2011, 01:32 PM   #10
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Do you need more then 15 amps right now? I would just run a heavy duty extension cord temporarily. It's only going to be there for 4 months or so until the ground unthaws, so it should be ok. Then I'd just do an underground feed.
Old 01-15-2011, 04:51 PM   #11
An old Tradesmen
I tried talking him into doing that. But for some reason, he can't wait(always wants everything done now, no matter what).
So I'm kind of stuck doing it now.
He has helped me move in the past a couple times. And is more reliable then most of my relatives when it comes to helping me. So I can't really refuse. Without burning a bridge.
Old 01-15-2011, 05:35 PM   #12
I would drop the cord, lay some 2x6's next to it, and nail some ply over the sleepers to protect until Spring thaw. If you can drive the spikes to hold down the wood until you can get a warm enough period to bury the line or Conduit.
Old 01-15-2011, 06:08 PM   #13
Rewards Points: 756
UF cable can be strung between poles. See code sections on Messenger Supported Wiring.
Mark
Old 01-15-2011, 08:00 PM   #14
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
beenthere; is this going to get installed right come spring or is this the final installation?
btw; do not use an aerial cable for a dog run. There is a story floating around about a woman that did. Killed the dog, her, and her kid if it's true.
Old 01-15-2011, 08:32 PM   #15
An old Tradesmen
It will be permanent.
