Idiots And 3-way Switches. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 10:28 AM   #1
Idiots and 3-way switches.
Already fixed, just thought I'd share this one.
My wife and I recently purchased a house in Saginaw, MI.
The house is fairly old, and was rented as a duplex for ~50 years.
In the stairwell going upstairs, there was originally a 3-way switch, with 1 switch at the base of the stairs, and 1 at the top.
Apparently somewhere along the way, someone with very limited electrical knowledge decided to replace one of the switches. The lights would only come on, if both switches were in the "up" position.
This was pretty obvious to me, that there was some serious wiring issues; or that one of the switches was broken.
When I finally got around to opening them; I found that, in the previous owner's infinite wisdom, replaced the 3-way switch at the top of the stairs, with a normal switch, and connected the "spare" wire to the ground, on the switch.
So, to make a long story short, when the switch at the bottom of the stairs was in the down position, the chassis of the switch at the top of the stairs was hot.
This just makes me wonder how many other surprises this house has in store for me.
V/r,
Mike
Conjur is offline   Reply With Quote
Old 06-18-2013, 10:30 AM   #2
joed's Avatar
Rewards Points: 11,588
How come the breaker didn't trip when the switch at the bottom was flipped? The ground must not be connected back to the panel.
Old 06-18-2013, 05:04 PM   #3
Resi EC
Rewards Points: 252
V/r,
Mike
So one of the travelers went to the ground screw on the switch yoke?
That old of a house I'm sure it had metal boxes, so they would have been hot also.
Must be an ungrounded system (no ground wires) other wise the breaker may have tripped as Joed suggests.
Glad you got it fixed
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-19-2013, 02:32 AM   #4
Most of this house is not grounded; the only grounded circuits seem to be the kitchens and bathrooms.
I have the wiring and panels to replace the entire system, but can't afford the permit yet :/
V/r,
Mike
Old 06-19-2013, 07:19 AM   #5
Rewards Points: 85
V/r,
Mike
Yikes!!! Hey! It happens!! Get this... When I bought my 1936 Tudor on LI ny I ventured into the attic to check out the insulation or lack there of. When I was crawling around I stumbled upon an old bx cable lying on top of the paper backed old insulation. Best part? The ends were exposed AND LIVE! One spark and poof!!!
JohnC20 is offline   Reply With Quote
Old 06-19-2013, 07:23 AM   #6
Rewards Points: 85
V/r,
Mike
When I was working on the three way switches last wknd (posted a q about it too) I also uncovered that the kitchen wasn't grounded. My colored plug in tester said so! Lol. While the wall was opened up I ran a shielded ground wire to each box and wrapped it around a water pipe. Waaa laaa grounded circuit.
Old 06-19-2013, 07:34 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
1) What is a "shielded ground wire"?
2) If that is truly how you did it, then Waaa laaa...code violation.
3) Since the walls were open, did you bring the kitchen up to code? 2 counter top circuits, GFI's, correct outlet spacing, tamper resistant receptacles
Old 06-19-2013, 07:43 AM   #8
Electrical Enthusiast
Rewards Points: 504
Insulated maybe?
Kyle_in_rure is offline   Reply With Quote
Old 06-19-2013, 12:52 PM   #9
Rewards Points: 85
K_buz... I get you may be a certified electrician and I'm not but yes, I replaced the old with TR receptacles all branched from a GFI. The ground I ran was a 12g green insulated wire between each box. Right? Wrong? How should I have done it??
Old 06-19-2013, 01:45 PM   #10
k_buz's Avatar
You would run a #12 from each box to either the grounding electrode system or the ground bar in the panel the circuit originates from. These connections would have to be made with listed connectors and remain accessible.
Old 06-19-2013, 07:20 PM   #11
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Should we start another thread about idiots and grounding devices?
Old 06-20-2013, 07:12 AM   #12
Rewards Points: 85
Sure! Lead the way!
Old 06-23-2013, 08:56 PM   #13
Rewards Points: 1,294
Sure! Lead the way!
Oh, boy. Let me get my popcorn
danpik is offline   Reply With Quote
Old 06-23-2013, 08:57 PM   #14
E2 Electrician
Don't bother, movie ended.
Old 06-23-2013, 10:05 PM   #15
" Euro " electrician
frenchelectrican's Avatar
Yeah but we haven't see the bounus section yet.,,
Merci,
Marc
Who posts here? or My Soapbox Minute CplDevilDog Off Topic 194 11-15-2011 07:09 PM
