Identify Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 03:09 AM   #1
Identify circuit breaker
Hi,
I'm in a house that is more than 50 years old, and the electrical panel says Square-D. One of the 20 amp single pole circuit breaker handle broke, and I took it out, and it has no markings, no manufacturer nor part number on it. The panel is nearly 4" in length. I went to Orchard Supply Hardware, Lowes and Home Depot and they all said they have nothing like it. Might be an obsolete thing.
Can anyone help identify it? Anyone know where I can find a replacement?
If I can't find a replacement, what can I do? I sure hope I don't have to replace the entire panel.
Thanks a lot.
olnoln is offline   Reply With Quote
Old 03-14-2010, 08:49 AM   #2
Electrical Contractor
kbsparky's Avatar
That's an X-O breaker. The buss bars are round -- they look like copper water pipes. You can orient the breaker on the right side, or the left, depending on which leg of the panel you want to connect to.
Here is one place to start looking for these. Be warned, they ain't cheap.
-KB
Old 03-14-2010, 10:15 AM   #3
If you have a Square D panel you should be installing Square D breakers
Was this breaker installed in the Square D panel ?
Or a sub-panel ?
Old 03-14-2010, 10:38 AM   #4
Master Electrician
Rewards Points: 3,768
An X-O is a Square D breaker.
brric is online now   Reply With Quote
Old 03-14-2010, 01:07 PM   #5
kbsparky's Avatar
Mostly true, however Square D sold the line to Cutler-Hammer when they developed a newer style of breaker line.
Some XO breakers have the Cutler-Hammer label on them because of this.
-KB
Old 03-14-2010, 07:12 PM   #6
Journeyman Wireman
Rewards Points: 150
We have a good source for recycled and/or obscure breakers here in Portland. I don't know if they do mail order but the link is
http://oregonbreaker.com/
BTW, I'm not affiliated with them in any way except that my shop buys from them when we need an oddball breaker.
Jupe Blue is offline   Reply With Quote
Old 03-16-2010, 12:11 AM   #7
Thank you so much for the helping me to identify it. Checking google does confirm that it looks like the XO120. But, oh boy, are they expensive for used ones, but I guess that can't be helped since they are now obsolete.
The bus bars are actually two flat bars, about .5in wide (didn't really measure it).
Thanks so much everyone.
Circuit breaker question kupalino Electrical 6 12-19-2009 12:35 AM
12 AWG circuit, Breaker 15A, 20A or either? SteveG Electrical 11 05-27-2009 01:05 PM
loose circuit breaker justorr Electrical 5 11-28-2008 04:14 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
