Identifing Circuits/Associated Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 08:30 PM   #1
A while back I posted a question about having a large house and needing to replace all the wall receptacles. Got a ton of replies but while in the HD, picking up some Behr Paint/Primer <BG> saw a Klein tool that has a transmitter that you plug into outlets and then scan the panel and it beeps when it finds it. Yahoo, it works and I can do it myself, would be better with a helper.
For the DIY'er if may be a tool than can help you out. It was a Klien ET300 and I have already started replacing outlets identified with the tool. One room done and well lots to go.
Wondering if anyone else uses this and any tips would be appreciated?
pinkfloyd43 is offline   Reply With Quote
Old 12-13-2012, 08:42 PM   #2
Rewards Points: 272
I've used one before with great sucess. Worked perfectly
speedster1 is offline   Reply With Quote
Old 12-13-2012, 10:15 PM   #3
Engineer
Rewards Points: 161
I've used one, and they're not too bad. Just like inductive testers, they're not to be considered a definitive measure. Always check the outlet for power after throwing the breaker.
diystephen is offline   Reply With Quote
Old 12-13-2012, 10:23 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Best thing to do with those is once you suspect you have found the correct breaker, turn it off. The signal will stop and you will know you have found the correct breaker. If you do not have the right breaker, the signal will continue to tone out.
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 12:23 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
