Ideal Placement Of Exterior Light - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 10:43 AM   #1
Rewards Points: 202
ideal placement of exterior light
Hi all, was not sure where to ask this question, but electrical seems the most logical---
I'm going to be installing a inswing patio door where there is currently a window. I am going to install sconce-type light on one side of the door. What is the ideal height of the light? what is the idea distance from the door Are there any suggestions or is it just "whatever looks good"?
Thanks!
benleef is offline   Reply With Quote
Old 01-14-2013, 10:50 AM   #2
Rewards Points: 13,250
You got it.
A light next to a door looks nice until you turn it on and it attacts all the bugs right where the door opens.
At least install it on the hindge side.
Make sure to install it where it's easy to get to the bulb without a ladder.
Old 01-14-2013, 10:51 AM   #3
the Musigician
DangerMouse's Avatar
I put mine about eye level, and around a foot away from the frame. You may want to check with your inspector to be sure there is not a requirement to be followed.
DM
Old 01-14-2013, 10:56 AM   #4
Rewards Points: 202
Originally Posted by joecaption View Post
You got it.
Thanks! I'm not sure installing it on the hinge side will "look best" though. But you make a good point about bugs!
Old 01-14-2013, 11:19 AM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I usually place them 12" down and 12" over to center of box from the top of door. It also depends on the fixture.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-14-2013, 02:01 PM   #6
Special User
Rewards Points: 1,230
I moved in to a house that had an exterior light at eye level. I hate it because it blinds me. I'd much rather have it 7-8ft off the ground, but that's just me.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Cold air return -- placement relative to the floor domh HVAC 1 10-16-2012 12:04 AM
Furniture placement question tamjamb Interior Decorating 14 08-23-2012 09:52 AM
Question about vent placement Sweet Lew Roofing/Siding 8 07-01-2011 11:43 AM
Rules for furniture placement for a living room? Bacardi 151 Interior Decorating 17 12-23-2008 11:49 PM
Sub-Panel Placement Question KC10KEVIN Electrical 10 05-09-2008 10:40 AM
