ICAT Can Leaks Heated Air Into Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 03:00 PM   #1
merdao
ICAT can leaks heated air into attic
All of the ICAT cans I viewed at several stores have a manufacturing gap between the can and the attic mounting flange causing a huge air leak from the room below! Would it be safe to seal the leak by applying aluminun duct tape, plumbers putty or acrylic caulk? I have a couple dozen cans to replace (old Non IC cans) in order to improve energy efficiency. Thanks
awclark@verizon is offline   Reply With Quote
Old 02-09-2011, 03:04 PM   #2
The appropriate trim ring will help cover the gap. Also, if you are using IC-rated cans, you can put insulation around them to further minimize any airflow. I would not modify the can or attach anything directly to it (remember, the can interior will heat up considerably when the light is on because it is airtight).
clashley is offline   Reply With Quote
Old 02-09-2011, 05:57 PM   #3
merdao
Thank you, I am still looking at a considerable air exchange. Maybe I'll look into fireproof furnace sealer. I have seen it being used on the furnace exhaust joints. It would be nice if the Fixture manufactuter would quit passing their stuff off as "AIR TIGHT"... The folks at the BOX stores are clueless...
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Plugging ceiling air leaks before insulating attic? dvs HVAC 5 12-02-2010 06:44 PM
chimney chase leaks into attic dadscady Roofing/Siding 16 10-08-2010 04:04 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 01:47 PM
Insulating walls between attic & heated area Hobiedog Remodeling 4 11-08-2007 04:56 PM
