Old 10-03-2007, 01:55 AM   #1
IC can temperature rating?
Can anyone tell me at what temperature the thermal protector on a IC rated can will turn the light off? I have not researched the manufacturers yet, hoped someone here might save me some time. Many Thanks.
scrapiron is offline   Reply With Quote
Old 10-03-2007, 02:12 AM   #2
" Euro " electrician
frenchelectrican's Avatar
it is pretty much up to the manufacter put in the thermal switch in there and they useally about 140°F - 200°F depending on how it set up and they will have max wattage labeled with the trims on it
Merci, Marc
NC code for Breaker amperage rating in new home for Water Heater, Dryer, Range? lynne Electrical 5 08-26-2007 09:44 PM
Temperature Differance Over Coil rjordan392 HVAC 9 08-11-2007 06:34 PM
temperature rating for Romex Clutchcargo Electrical 7 07-24-2007 07:54 PM
Is there a way to circulate the outside temperature (air) into my home & take out hot 915855 Building & Construction 6 10-14-2006 04:19 PM
