IC Can Lights Still A Problem In My 2001 Build? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 09:52 AM   #1
IC can lights still a problem in my 2001 build?
My home was built in 2001, split level with 14ft cathedral ceiling for kitchen/dining/living room.
In the kitchen there are 4 adjustable eyeball can lights, the enclosures are IC rated but the trims are not "air tight"... is it worth putting CFLs in these enclosures, caulking the bases to the drywall and foil taping the holes in the enclosure?
I have 18" of cellulose atop them, but am wondering if this is leaking any appreciable amount of air? Do they make a swiveling air tight trim for a 6" light?
ls3c6 is offline   Reply With Quote
Old 01-12-2012, 10:37 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ls3c6 View Post
...14ft cathedral ceiling ... 4 adjustable eyeball ... IC rated .. 18" of cellulose...
If you have access to the space above... check/seal them.
A house built in 2001 *should* have had this sealing done when built.
If no access from above and if they are leaking any appreciable amount of air...
then sure, caulk at the the drywall opening behind the trims.
While you're up there? Sure; why not.
Old 01-12-2012, 01:05 PM   #3
No reason to use air tight unless it's in a wet location. Leave the can alone, led bulbs are much better than cfls especially if you want to dim them. Add more insulation if you feel air drafts around the cans.
Knauer is offline   Reply With Quote
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Problem with lights surging ram318 Electrical 5 02-22-2006 07:01 PM
