Old 05-22-2009, 10:08 PM   #1
I think my electrician messed up...help!
I had an electrician out to install a 100amp sub-panel. My main breaker had no slots left. The new one will be just for the home theater I'm building. I posted this photo on a home theater forum that I go to. They noticed that the electrician I hired did not run a ground from the main panel. They also stated that he used the wrong type of connectors on the conduit. I questioned him on running the ground and he stated that the conduit acts as a ground in this situation. I thought that a ground wire needed to be run when installing a subpanel. If it does, does the ground need to be housed in conduit? What do you all think?
jailbird371 is offline   Reply With Quote
Old 05-22-2009, 10:11 PM   #2
GC/Master Plumber/Mech
I think that if the main panel is bonded then the conduit to the sub panel is acceptable as a ground.
Old 05-22-2009, 10:13 PM   #3
Bigplanz's Avatar
Did you get it inspected?
Bigplanz is offline   Reply With Quote
Old 05-22-2009, 10:17 PM   #4
No, I didn't.
Old 05-22-2009, 10:18 PM   #5
My License Ain't 4 Sale..
Tell the hacks on the home theater forum to stick to home theatering...
That is actually a better looking install than most pics we get here. The conduit is a legal ground when properly installed. I personally always pull a ground, but I'm OCD like that. The type of connectors used is fine, as long as they were tightened by wrench or pliers.
Just judging by the way the setup looks, I'd say the installer cared enough to do it right, and everything is fine. I would have bent my conduit different, but it is still fine.
P.S.: You do need a ground bar in the panel, however. I don't see one in there..
Old 05-22-2009, 10:20 PM   #6
Thanks for putting my mind at ease.
Old 05-22-2009, 10:25 PM   #7
Just for the record....it wasn't the home theater forum on this site.
Old 05-22-2009, 10:28 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Agree on all points.
Personally I would have mounted a clean painted plywood board to the foundation and mounted the panel to that.
Does your area require the use of conduit?
Was this a side-job from a union or commercial/industrial electrician? That is the impression I get.
Old 05-22-2009, 10:34 PM   #9
Just wondering, as I plan on having a sub panel ran into my garage... If conduit can/is being used as the ground does thee 90 to the panel need to be metal too, or is the use of plastic ok? Or is it metal and just looks to be PVC in the pic.
mgarfield is offline   Reply With Quote
Old 05-22-2009, 10:35 PM   #10
Wow! You're good! Exactly! (commercial)
Old 05-22-2009, 10:36 PM   #11
I thought the same thing, but I "think" it is aluminum.
Old 05-22-2009, 10:42 PM   #12
Electrical Contractor
If using the conduit as ground, it has to be metal all the way.
The lb is potmetal, and looks like pvc.
Add the extra $$$ and run a ground wire.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 05-22-2009, 10:45 PM   #13
I don't mind having a ground run to be safe, but does it have to be run in a conduit? Can it be a fleible conduit like "smurf tube" I don't think it is feasable to run another one like he did...at least in the same place.
Old 05-22-2009, 10:48 PM   #14
Ok, cool. And that is some nice wire work.
Old 05-22-2009, 10:56 PM   #15
That makes a lot of sense!
complicating-updating new box for client, electrician messed it up-pics included Kraze Electrical 29 11-18-2012 10:14 PM
How to find a good electrician farmerde Electrical 16 02-24-2009 10:46 AM
Can I pre-run romex before the electrician shows up? jheavner Electrical 14 10-10-2008 02:00 PM
help electrician failed to show.NEWB post gotsig Electrical 25 05-26-2008 10:28 PM
North Carolina Electrician assistance please buloni Electrical 2 12-03-2005 09:07 PM
