-   -   I think my electrician messed up...help! (http://www.diychatroom.com/f18/i-think-my-electrician-messed-up-help-45045/)
jailbird371 05-22-2009 09:08 PM
I had an electrician out to install a 100amp sub-panel. My main breaker had no slots left. The new one will be just for the home theater I'm building. I posted this photo on a home theater forum that I go to. They noticed that the electrician I hired did not run a ground from the main panel. They also stated that he used the wrong type of connectors on the conduit. I questioned him on running the ground and he stated that the conduit acts as a ground in this situation. I thought that a ground wire needed to be run when installing a subpanel. If it does, does the ground need to be housed in conduit? What do you all think?
http://i10.photobucket.com/albums/a1...e/IMG_4530.jpg
Plumber101 05-22-2009 09:11 PM
I think that if the main panel is bonded then the conduit to the sub panel is acceptable as a ground.
Bigplanz 05-22-2009 09:13 PM
38 Attachment(s)
Did you get it inspected?
jailbird371 05-22-2009 09:17 PM
No, I didn't.
InPhase277 05-22-2009 09:18 PM
Tell the hacks on the home theater forum to stick to home theatering...
That is actually a better looking install than most pics we get here. The conduit is a legal ground when properly installed. I personally always pull a ground, but I'm OCD like that. The type of connectors used is fine, as long as they were tightened by wrench or pliers.
Just judging by the way the setup looks, I'd say the installer cared enough to do it right, and everything is fine. I would have bent my conduit different, but it is still fine.
P.S.: You do need a ground bar in the panel, however. I don't see one in there..
jailbird371 05-22-2009 09:20 PM
:laughing:
Thanks for putting my mind at ease.
jailbird371 05-22-2009 09:25 PM
Just for the record....it wasn't the home theater forum on this site.
Speedy Petey 05-22-2009 09:28 PM
Agree on all points.
Personally I would have mounted a clean painted plywood board to the foundation and mounted the panel to that.
Does your area require the use of conduit?
Was this a side-job from a union or commercial/industrial electrician? That is the impression I get.
mgarfield 05-22-2009 09:34 PM
Just wondering, as I plan on having a sub panel ran into my garage... If conduit can/is being used as the ground does thee 90 to the panel need to be metal too, or is the use of plastic ok? Or is it metal and just looks to be PVC in the pic.
jailbird371 05-22-2009 09:35 PM
:thumbup::thumbup::thumbup::thumbup::thumbup:
Wow! You're good! Exactly! (commercial)
jailbird371 05-22-2009 09:36 PM
I thought the same thing, but I "think" it is aluminum.
jbfan 05-22-2009 09:42 PM
If using the conduit as ground, it has to be metal all the way.
The lb is potmetal, and looks like pvc.
Add the extra $$$ and run a ground wire.
jailbird371 05-22-2009 09:45 PM
I don't mind having a ground run to be safe, but does it have to be run in a conduit? Can it be a fleible conduit like "smurf tube" I don't think it is feasable to run another one like he did...at least in the same place.
mgarfield 05-22-2009 09:48 PM
Ok, cool. And that is some nice wire work.
jailbird371 05-22-2009 09:56 PM
That makes a lot of sense!
