I Think I Got Crappy Service - What Should I Ask To Get Fixed? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 07:06 PM   #31
Rewards Points: 150
Originally Posted by danielrg
Internal panel is a 16/24. I actually have the cover off in the picture, I was inspecting his work. It's not live right now.
Hey guys, is that a common bonding jumper? I just never saw it done that way
Sunny B. is offline   Reply With Quote
Old 09-24-2011, 07:07 PM   #32
Rewards Points: 150
Originally Posted by Code05
Is that the panel bond screw in the neutral bar?
Is that a home made jumper across the neutral busses?
"laughing" you read my mind
Old 09-24-2011, 07:10 PM   #33
Rewards Points: 150
This is a disgrace. He should be embarrassed
Old 09-24-2011, 07:13 PM   #34
Code05's Avatar
Rewards Points: 1,104
That is because it is not done that way. Note the size of the jumper compared to the neutral.
If it is a factory bar it would be okay.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
danielrg (09-24-2011)
Old 09-24-2011, 07:26 PM   #35
Electrical Contractor
kbsparky's Avatar
That green-looking screw needs to be removed. It may not have been tightened down, but in any case, it should not be present.
The siding was a hack job. A decent siding block (or 2 in this case) would have gone a long way to ensure the job looked better:
2 of those stacked up would have done the trick, with the built-in "j" channel making it a 1st class installation.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 09-24-2011, 07:41 PM   #36
Code05's Avatar
Yeah, that would have been best.
You familiar with Siemens panels? Is that a factory jumper?
Old 09-24-2011, 08:01 PM   #37
Rewards Points: 150
Sometimes it's not a good idea to go with the lowest bidder huh "laughing"
Old 09-24-2011, 09:00 PM   #38
kbsparky's Avatar
Originally Posted by Code05 View Post
...You familiar with Siemens panels? Is that a factory jumper?
Yes, it is. In fact, one could have removed that jumper, put the green screw on the other side, and not needed an additional equipment grounding bar.
But, since they did install a separate EG bar, the jumper can remain, making both sides for neutral wires.
But now that green screw has to go.
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
danielrg (09-24-2011), SD515 (09-25-2011)
Old 09-24-2011, 09:23 PM   #39
Code05's Avatar
Strange, a copper jumper in an all AL panel.
Yeah, I would have done the same: 1 lug is cheaper than a ground bar.
I thought screw was the panel bond, but could not tell if was really green on my screen.
This "electrician" is real winner-not.
That siding is gonna be a PITA to fix.
Old 09-24-2011, 10:34 PM   #40
Rewards Points: 83
Thanks for all the comments. I think I understood most of what you are saying. The mounting panel looks nice. Sigh...
He wasn't even the low bidder. I had a neighbor bid who was lower, but he took forever to bid and I was all setup, appointments, etc. so I went with this guy. Turns out the neighbor has a good reputation doing commercial work, and he is good friends with the owner of another company that does lots of residences in my area. He came over and looked at the job and felt pity for me. I could see it in his eyes. He said I would've been better off with either of the other bids.
It's true. I am humbled.
Only thing I didn't understand was this comment:
Anyone care to explain? What's "1 lug" mean?
danielrg is offline   Reply With Quote
Old 09-24-2011, 10:38 PM   #41
Code05's Avatar
Look at where the large wires are terminated. Those are lugs. You can add one to a buss.
Old 09-24-2011, 10:59 PM   #42
Just goes to show ya, if the ac guy doesn't get you, sparky will....
Master of Cold is offline   Reply With Quote
Old 09-25-2011, 03:00 PM   #43
Electrician
SD515's Avatar
Rewards Points: 504
As to the sub-panel…
The ‘Angel wings’ the {eh-hem} “installer” put in the wires of the feeder before they enter the lugs…having them ~6 inches shorter would look nicer and more professional.
Kyle
Old 09-25-2011, 09:50 PM   #44
" Euro " electrician
frenchelectrican's Avatar
It look little sloppy when someone bring the cable in however there one thing I learn long time ago I don't use the same hole for SE-R and NM cable and also to be on safe side you should have nail plate on it for extra safety mesure in case someone try to drive long arse screw or nail even thru you are centred on the stud { that can happend once a while.}
For the outdoor all in one box I wil spend little extra time to make it neat not that sloppy like you posted in the photo.
Oh yeah.,, get rid of vert ( green ) screw
Merci,
Marc
Old 09-26-2011, 05:23 AM   #45
Electrician
SD515's Avatar
Rewards Points: 504
Good eye Marc.
Also, hard to tell, but it looks like the romex connector on the 10/3 in the sub-panel is missing the lock-nut??
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
frenchelectrican (09-27-2011)
"Moving" service entrance WillK Electrical 4 09-29-2010 01:04 PM
Central A/C Service Costs brentp Off Topic 9 05-25-2010 07:25 PM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Under-rated service drop? fw2007 Electrical 5 07-08-2008 07:24 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 10:04 AM
