I passed Rough-In
Thanks for the input guys....
For the record...I've never seen the derating tables before...even though I design a lot of control systems using conduit, I've never had to worry about it...my only concerns are conduit fill. All of my wires are basically low current....for the most part, I'll have 50-300 THHN wires in multiple conduits....and all of that is protected with a couple 10 or 15A breakers....
Raceway vs conduit....I use both....they are two different animals...though I can see treating them the same as far as derating goes.
I've been looking at the NEC tables....seeing how I'm using THWN/THHN 90 deg C wire....I think I'm ok on the derating....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
