I Need To Tap Into A 4 Wire Circuit.... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2008, 08:21 AM   #1
I need to tap into a 4 wire circuit....
Hello, I am new to this site but have been renovating our 120 year old farm house for a few years now. I found this site because I feel I would have more to offer in a DIY forum than in a specialized forum.
Years ago I removed an old beat up attic fan that had been running off a junction box that was basically a 4wire set that had been hacked and the fan patched in. I recapped everything but now I need to install a new fan in its place. I would like to use the available junction box but did not note which wires were being used.
The fan only has black & white, which I connected to matching b&w and it did not work. I then swapped the fans black wire to the red and left the white on white, but still did not work. Am I missing something? Please help!
SB
jiggysmb is offline   Reply With Quote
Old 06-14-2008, 08:36 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Is it still hooked up in the panel? Do you have a voltage tester?
wirenut1110 is offline   Reply With Quote
Old 06-14-2008, 08:43 AM   #3
Yes it is still attached to the panel and the switch I believe it goes to has the red and black wires on one side and the white on the other if that is any help. The only tester I own in a multimeter but can pick a voltage tester if recommended.
Old 06-14-2008, 08:48 AM   #4
Rewards Points: 510
That sounds like a 3-way switch configuration. Given that, the white isn't a neutral. On the switch, does it have a black screw or say "common"? Pictures are worth a 1000 words.
Old 06-14-2008, 09:56 AM   #5
ok I hope this is meaningful....
The 4 wire cable goes from the panel to this switch, you see the red & black with white on the other side
This switch on the left will also operate the same light
Maybe I should just try to tap in elsewhere because my wife may want a dimmer on this light down the road for our new baby.
Last edited by jiggysmb; 06-14-2008 at 09:57 AM. Reason: dont know my left from right
Old 06-14-2008, 10:09 AM   #6
Rewards Points: 510
Yeah, this is a 3-way. Probably prior they were using the ground for a neutral (please don't do this, please) you need to find a circuit in the attic that's hot all the time. Is there a light or receptacle in the attic?
Old 06-14-2008, 10:26 AM   #7
Thanks wirenut! I kind of got the feeling this wasnt the correct way to get it done. I will explore other options.
Old 06-14-2008, 12:13 PM   #8
Idiot Emeritus
Rewards Points: 1,492
If you have a doorbell, there's usually a transformer somewhere in the attic. The box it's mounted on is another place to find a circuit thats always hot.
Rob
micromind is offline   Reply With Quote
Old 06-21-2008, 07:33 PM   #9
wirenut- I wanted to thank you. You saved me from doing this project in a rushed state and today I was able to spend an hour running a new cuircut from a 2nd floor sub panel that was recently installed for my AC unit. Turned out to be a fairly easy job and I have you to thank from saving me from a rig job that could of caused many problems down the road!
Old 06-21-2008, 07:58 PM   #10
Rewards Points: 510
Glad to be of assistance.
Old 06-21-2008, 10:43 PM   #11
Advice worth 2 cents!
Rewards Points: 150
Hmmm...glad to see your trying but, be careful, doing electrical work is not trial and error!!!!
-pete
---pete
HandyPete is offline   Reply With Quote
Circuit breakers and wire size stan 41943 Electrical 19 03-06-2008 03:29 PM
Where to wire in to circuit brackh Electrical 5 02-28-2008 07:04 AM
Using 14/2 wire on 20 amp circuit mohairy Electrical 1 12-29-2007 07:26 AM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 09:23 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
