I Need Suggestion / Advice On LED-based Lighting Solution For My Basement. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-04-2013, 07:35 PM   #16
Bill Kearney
Rewards Points: 1,174
No dimmers? With that many fixtures? Not sure I'd make that bet. I'd at least plan for dimmers, specifically ones that were known to already work with the can and bulb setup.
wkearney99 is offline   Reply With Quote
Old 06-04-2013, 09:16 PM   #17
747
registered
747's Avatar
Rewards Points: 534
Slap some slick track lightening down there. You can actually adjust them on the rail. They have came a long way since back in the day.
747 is offline   Reply With Quote
Old 06-04-2013, 09:21 PM   #18
Electrical Contractor
kbsparky's Avatar
Try this one instead:
http://www.homedepot.com/p/Lithonia-...3#.Ua6gRdJ1-SA
20 bucks cheaper each, and with brand-name quality too.
-KB
Old 06-05-2013, 09:00 AM   #19
Rewards Points: 150
Originally Posted by mystiky View Post
After your help and some research, I have decided to go with Cooper Lighting RL560 "Halo". They are sold in both Home Depot and Lowes:
http://www.homedepot.com/p/Halo-6-in...specifications
Before I go and buy about 25 of these, does anyone know or are aware of anything negative about this model?
I would check out the LEDR56_3K from Menards. 75W equiv (vs 65W on yours, 840 lumens vs 600-ish lumens) and only $35 - 11% = $31 ea vs $50 you're paying.
If you're buying 25 of them that's about $500 saved.
I tried the Home Depot flush model, HD gimball model, and Menards flush model all in the same room and I liked these best.
SquishyBall is offline   Reply With Quote
best door solution for basement under ductwork joem01 Building & Construction 10 01-18-2012 01:15 PM
Advice on priority of repairs: gutters and basement nshroyer Building & Construction 10 07-06-2011 08:40 PM
Colors & Decorating Advice for Basement Remodel gunderson99 Painting 3 07-05-2011 11:19 AM
Temporary Solution for Severe Basement Mold Problem denny888 General DIY Discussions 1 09-08-2010 12:32 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
