I Need Some Aluminum Wiring Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 01:01 PM   #1
I need some Aluminum Wiring help.
HI All
I have Aluminum wiring in my home. It was build in 1971. I want to install some dimmers and GFI outlets. What do you recommend: 1. buying aluminum rated outlets and dimmers. or 2. Buying a the dimmer and using aluminum to copper murrets with the paste inside of them?
I have been searching the internet for some videos or guides on this procedure. Have you done it before? Any tips or tricks you can share? I am going to try to do this myself.
thanks for the help.
g
octapuss is offline   Reply With Quote
Old 08-30-2012, 01:07 PM   #2
Rewards Points: 6,652
What part of Canada are you in? Just for others, this post ties into anyone had to change a glass fuse box over to a circuit breaker box?
Old 08-30-2012, 01:15 PM   #3
I am in toronto.
Old 08-30-2012, 05:28 PM   #4
Licensed electrician
Rewards Points: 1,278
I have never seen a dimmer or GFI listed for use with AL in the US.
Old 08-30-2012, 06:53 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
me neither...
Old 08-30-2012, 10:28 PM   #6
if there is not dimmers or gfi's then i should use the pigtail method? Use the paste and murrets?
anyone with a good idea on how to tackle this?
Old 08-30-2012, 10:30 PM   #7
E2 Electrician
I would use this product from King Innovations AlumiConn Lug Connector-95125
Old 08-31-2012, 04:06 PM   #8
I am a bit of a noob at this. Is that some sort of murret? Could you give me a bit of an explanation?
thanks for helping!
g
Old 08-31-2012, 04:50 PM   #9
That performs the same function as your Marrettes, but is more like a terminal strip.
Aluminum may not be the best place for you to get your feet wet. The older AL was brittle and breaks easily.
Old 09-02-2012, 05:22 PM   #10
A termina, which makes sense. Ill look around if there are some at the local hardware stores. I am going to go slow and see if i can learn to do this. I might also buy some aluminum rate dimers.
Connecting 4 aluminum wires in a junction box krick Electrical 3 07-21-2012 03:06 PM
Aluminum Wiring for Range bob22 Electrical 3 07-24-2010 08:38 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 12:20 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
