-   -   I need some Aluminum Wiring help. (http://www.diychatroom.com/f18/i-need-some-aluminum-wiring-help-155320/)
octapuss 08-30-2012 01:01 PM
HI All
I have Aluminum wiring in my home. It was build in 1971. I want to install some dimmers and GFI outlets. What do you recommend: 1. buying aluminum rated outlets and dimmers. or 2. Buying a the dimmer and using aluminum to copper murrets with the paste inside of them?
I have been searching the internet for some videos or guides on this procedure. Have you done it before? Any tips or tricks you can share? I am going to try to do this myself.
thanks for the help.
g
gregzoll 08-30-2012 01:07 PM
What part of Canada are you in? Just for others, this post ties into http://www.diychatroom.com/f18/anyon...er-box-153219/
octapuss 08-30-2012 01:15 PM
I am in toronto.
Jim Port 08-30-2012 05:28 PM
I have never seen a dimmer or GFI listed for use with AL in the US.
stickboy1375 08-30-2012 06:53 PM
12 Attachment(s)
me neither...
octapuss 08-30-2012 10:28 PM
if there is not dimmers or gfi's then i should use the pigtail method? Use the paste and murrets?
anyone with a good idea on how to tackle this?
stickboy1375 08-30-2012 10:30 PM
12 Attachment(s)
http://www.landscapelightwerks.com/i...nd/1860std.jpg
I would use this product from King Innovations AlumiConn Lug Connector-95125
octapuss 08-31-2012 04:06 PM
I am a bit of a noob at this. Is that some sort of murret? Could you give me a bit of an explanation?
thanks for helping!
g
Jim Port 08-31-2012 04:50 PM
That performs the same function as your Marrettes, but is more like a terminal strip.
Aluminum may not be the best place for you to get your feet wet. The older AL was brittle and breaks easily.
octapuss 09-02-2012 05:22 PM
A termina, which makes sense. Ill look around if there are some at the local hardware stores. I am going to go slow and see if i can learn to do this. I might also buy some aluminum rate dimers.
