Old 07-17-2012, 10:52 PM   #1
i need to know how to calculate how much wire per sq ft to buy
I am planning to buy a huge home from early 1900's. Without adding the basement and attic the sq ft is about 4700 for both floors together. The lady got an estimate of 9k For a contractor to do it but i want to do it myself. Is there an easy way to go by sq footage on how much materials alone will cost?
ddavis14 is offline   Reply With Quote
Old 07-17-2012, 11:45 PM   #2
Master Electrician
That price is pretty good for a place that size I would think. Until you figure out how you want to do everything then there's no way you can just guess at what it will cost. I've never seen anyone do an estimate without a set of prints to do a take off from.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-17-2012, 11:51 PM   #3
Licensed Electrician
k_buz's Avatar
Professional electrical contractors argue over pricing new homes by square foot. Without knowing what your home currently has, or a set of prints, there would be no way to even guess.
Keep in mind, when you rewire a house, you need to bring everything up to code...kitchen circuits, laundry circuits, bathroom circuits, GFI's, AFCI's, and tamper-proof receptacles just to name a few. It is not acceptable to simply run new wires to the existing boxes.
Location...Location...Location
Old 07-18-2012, 12:05 AM   #4
Thanks for the advice.
Old 07-18-2012, 12:57 AM   #5
Have you even checked to see if you can pull a permit for this as a home owner?
Going to have to trust me I'm not trying to give you a hard time on your post, it's just I've been doing this stuff for a very long time and have seen way to many people that have been wathing those silly DIY shows and the ones where they buy a house and 2 weeks later make $100,000.
99.9% percent of the time it's just not going to happen.
Take what you think it's going to cost and double up and you will be close.
Speedy Petey (07-18-2012)
Old 07-18-2012, 07:05 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
IMPOSSIBLE.
IF, and only IF, we had a set of prints showing everything you wanted, you MIGHT be able to get within 20-40% correct. Going simply by sq/ft you might get close for a bare minimum code required job.
It also depends on if you need a service or not.
$9K sounds WAY too cheap IMO. And that HAS to be without a service change/upgrade. The 400A service you'll need will likely be in the $3500 range alone.
Old 07-18-2012, 08:19 AM   #7
You may wish to consult with the city inspector about adding new circuits and perhaps putting in a new service while existing circuits remain intact and in use, and also a timeline for when bringing the entire house up to code needs to be completed. (The full answer may depend on how much new work is planned.)
(Note that you may not add on to (extend) an existing non-compliant circuit for example an ungrounded circuit.)
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 07-18-2012, 06:05 PM   #8
It was a dark and stormy
Yoyizit's Avatar
The total wire length req'd probably correlates better to the number and perimeters of the rooms rather than the house sq. footage.
If there are any houses under construction near you, you can see how the wire is routed in the walls. Mostly horizontally, some diagonally, some vertically.
This calc. is tedious but it may be worth it to you to do it.
Old 07-18-2012, 06:39 PM   #9
Licensed electrician
You could install a code minimum or add in all the bells and whistles and the square footage would be the same. Wiring is not like paint, drywall or flooring.
Old 07-18-2012, 08:08 PM   #10
JOATMON
ddawg16's Avatar
If your going to go through all that trouble to rewire.....the cost of the wire is nothing compared to the labor and other materials.
First thing you need to figure out is how many ckts.....I doubt you want to duplicate what is there....otherwise, why bother. Your going to want new lights in new locations...more switches....more outlets.....
Assuming you can do the work yourself (if you were in California, no problem doing it yourself), you will most likely have to bring all of the electrical up to current standards....AFIC for all the bedrooms....wired smoke and CO detectors.....an outlet on each wall....each bathroom with it's own dedicated outlet....all light switches have to have a neutral....etc.
Yea...$9k sounds cheap....almost too cheap for a house that size...I just bougt a 250' roll of 12/2 the other day at HD...$79.....house your size could require anywhere between 5 to 10 rolls like that....depending on what all you do.
You have a lot of homework ahead of you......I would start off by making a dwg of each room and start planning what goes where....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 07-19-2012, 03:39 PM   #11
Yoyizit's Avatar
Here's a formula that should correlate well for a one room house where the room is square and has no ceiling fixture.
L = 4 x sqrt(A), where L is the total wire length and A is the room area.
If A = 100 sq. ft, L = 40' of wire. For A=1000 L = 126' and for 2000 it's 179'.
For non-square rooms and multistory houses it gets more complex.
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
