I Need Help With Wiring With Romax - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 08:01 PM   #1
i need help with wiring with romax
If i have a single pole switch controls both a light and half of a receptacle and the other half of the recepticale is always hot how do i install? if any one has a wiring diagram that would be very helpful too. thank you!
smoothinstall is offline   Reply With Quote
Old 11-23-2008, 08:25 PM   #2
here is a quick simple diagram. you'll need 14-3 from the switch to the light to the receptacle, if you have any more questions let me know
Sliver is offline   Reply With Quote
Old 11-23-2008, 08:30 PM   #3
Just make sure you break the tab on the hot side of the receptacle.
jerryh3 is offline   Reply With Quote
Old 11-23-2008, 08:32 PM   #4
same
i am sorry but can you show me a diagram if the supply is coming from the recepticle and color should i use for my switch leg?
Old 11-23-2008, 08:37 PM   #5
i have the power coming in from the recepticle then i have my switch then a light how would i wire that up with romax wire. please show diagram if possible. thank you!
Old 11-23-2008, 08:45 PM   #6
more like this
Old 11-23-2008, 08:48 PM   #7
What is the breaker size?
20=12 awg
15= 14 awg
rgsgww is offline   Reply With Quote
Old 11-23-2008, 08:54 PM   #8
what color should i use for the switch leg
Old 11-23-2008, 08:58 PM   #9
you'll need to use 14-3 (12-3 if its a 20A circuit) from the recep. to the switch, White must be neutral, your black and red are hots, one will connect to the supply, one will be your switch leg color does not matter on this... then to the light you will us 14-2, white is neutral, black will connect to the switched wirenut
Old 11-23-2008, 09:00 PM   #10
Assuming its 15 amps, 12-2 if its 20.
Old 11-23-2008, 09:08 PM   #11
I really need to stop assuming... its a bad habit.
Old 11-23-2008, 09:09 PM   #12
thank you
but i have a another question to ask. with romax again i have the power coming from the switch that controls 2 different lights then there is a recepticle but thats always hot. how would i wire that?
Old 11-23-2008, 09:18 PM   #13
thank you
White is Neutral all the way through, Black is hot all the way through, red is switched.
Old 11-23-2008, 09:30 PM   #14
thank you sliver that helped alot. are you a electrician?
Old 11-23-2008, 09:41 PM   #15
I'm 1.5 years through a 2 year construction electricity program...
Not yet, in about 7 months I hope to start my apprenticeship... if i can find a job
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 11:52 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
