-   -   i need help with wiring with romax (http://www.diychatroom.com/f18/i-need-help-wiring-romax-32490/)
smoothinstall 11-23-2008 08:01 PM
If i have a single pole switch controls both a light and half of a receptacle and the other half of the recepticale is always hot how do i install? if any one has a wiring diagram that would be very helpful too. thank you!
Sliver 11-23-2008 08:25 PM
1 Attachment(s)
here is a quick simple diagram. you'll need 14-3 from the switch to the light to the receptacle, if you have any more questions let me know
jerryh3 11-23-2008 08:30 PM
Just make sure you break the tab on the hot side of the receptacle.
smoothinstall 11-23-2008 08:32 PM
same
i am sorry but can you show me a diagram if the supply is coming from the recepticle and color should i use for my switch leg?
smoothinstall 11-23-2008 08:37 PM
i have the power coming in from the recepticle then i have my switch then a light how would i wire that up with romax wire. please show diagram if possible. thank you!
Sliver 11-23-2008 08:45 PM
1 Attachment(s)
more like this
rgsgww 11-23-2008 08:48 PM
1 Attachment(s)
What is the breaker size?
20=12 awg
15= 14 awg
smoothinstall 11-23-2008 08:54 PM
what color should i use for the switch leg
Sliver 11-23-2008 08:58 PM
you'll need to use 14-3 (12-3 if its a 20A circuit) from the recep. to the switch, White must be neutral, your black and red are hots, one will connect to the supply, one will be your switch leg color does not matter on this... then to the light you will us 14-2, white is neutral, black will connect to the switched wirenut
rgsgww 11-23-2008 09:00 PM
Assuming its 15 amps, 12-2 if its 20.
Sliver 11-23-2008 09:08 PM
I really need to stop assuming... its a bad habit.
smoothinstall 11-23-2008 09:09 PM
thank you
but i have a another question to ask. with romax again i have the power coming from the switch that controls 2 different lights then there is a recepticle but thats always hot. how would i wire that?
Sliver 11-23-2008 09:18 PM
1 Attachment(s)
Originally Posted by smoothinstall (Post 189269)
thank you
White is Neutral all the way through, Black is hot all the way through, red is switched.
smoothinstall 11-23-2008 09:30 PM
thank you sliver that helped alot. are you a electrician?
Sliver 11-23-2008 09:41 PM
I'm 1.5 years through a 2 year construction electricity program...
Not yet, in about 7 months I hope to start my apprenticeship... if i can find a job
