I Need Help With Electrical Wiring. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 05:52 PM   #1
I need help with electrical wiring.
Hi all, I'm new here I love trying to teach myself new things and this is my first post on DIY. I am building a swamp cooler as per the instructable
http://www.instructables.com/id/Port...-swamp-cooler/
I would like to wire my pump and fan to use in a regular wall outlet, and plan to at some point modify it for solar use. Here's what I got.
A Bilge pump with a 2 amp fuse 12 volt dc with a red and black wire which I assume will need to be soldered to something.
I am also waiting on a 1984 yahama venture radiator fan motor which I believe is also 12 volts.
Here's the question
What is the best, safest, and most efficient way for a DIY beginner to properly wire these two items to plug into a single electrical outlet?
What parts do I need how should they be assembled?
twilightofidols is offline   Reply With Quote
Old 07-16-2011, 06:04 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,882
Sign up for the site, since the instructions on wiring this up are only available that way.
Old 07-16-2011, 06:47 PM   #3
I=E/R
a7ecorsair's Avatar
Since the site you are following says it self contained - off grid operation, one way would be to use a deep cycle battery and a battery charger.
a7ecorsair is offline   Reply With Quote
Basement Electrical Wiring Question psqually Electrical 11 05-15-2011 05:18 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 05:53 PM
electrical wiring new construction 63Falcon Electrical 1 11-07-2010 04:31 PM
electrical wiring home ? dcjcdc Electrical 19 07-27-2010 09:38 AM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 05:40 PM
