I Need Help With This Electrical Diagram - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-09-2013, 02:51 PM   #31
Rabidcapybara's Avatar
Rewards Points: 35
Does this look ok?
Rabidcapybara is offline   Reply With Quote
Old 12-09-2013, 03:43 PM   #32
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Originally Posted by Rabidcapybara View Post
Does this look ok?
BINGO! The hot and neutral on the switch travelers and the lamp on the switch commons.
That's the circuit, just don't try to wire it as it is dangerous and non compliant.
There is no compliant way to wire the circuit you describe.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-09-2013, 03:48 PM   #33
Rewards Points: 35
Just wondering what would happen when the neutral goes on the brass and when the hot goes on the silver screw :S
Old 12-09-2013, 03:53 PM   #34
A "Handy Husband"
rjniles's Avatar
Are you talking about the terminals of the lamp? That is when the shell of the lamp socket is hot. The lamp doesn't care, it will work fine.
The Following User Says Thank You to rjniles For This Useful Post:
Rabidcapybara (12-09-2013)
Old 12-09-2013, 04:04 PM   #35
the circuit will 'work' in that the light will go 'off' but in one of the switch configurations, both lamp terminals are hit with 120V. the light won't illuminate since there is no voltage difference between the terminals but if you touched the lamp socket, it would be no different than sticking your finger in a receptacle.
itsnotrequired is offline   Reply With Quote
Old 12-09-2013, 07:25 PM   #36
joed's Avatar
Rewards Points: 13,340
You unscrew the bulb part way and accidentally touch the screw base of the bulb as it comes out of the socket, you get electrocuted.
Old 12-09-2013, 07:38 PM   #37
Rewards Points: 35
electrocuted or shocked?
Old 12-09-2013, 09:07 PM   #38
220,221,whatever it takes
Rewards Points: 33
Same thing. Electrocuted doesn't necessarily mean death.
Bernie Brewer is offline   Reply With Quote
Old 12-09-2013, 11:49 PM   #39
Oso954's Avatar
Rewards Points: 1,332
Wrong!
Look it up.
Oso954 is online now   Reply With Quote
Old 12-10-2013, 03:59 AM   #40
Electrical Contractor
kbsparky's Avatar
One can lead to the other:
Shocked, and if severe enough, electrocuted.
Nasty business ....
-KB
Old 12-10-2013, 05:50 AM   #41
Philly Master's Avatar
Rewards Points: 516
delete
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 12-10-2013, 05:56 AM   #42
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Sure it will work. It is not compliant or safe, but it will work.
Old 12-10-2013, 10:05 AM   #43
Rewards Points: 35
Thanx for all the help worked perfectly but not wired to code. I cannot put neutrals into switches! Any other ideas guys?
Old 12-10-2013, 11:46 AM   #44
is the expectation for it to be code-compliant?
Old 12-10-2013, 12:00 PM   #45
Rewards Points: 35
yes it has to be code-compliant
Electrical diagram for 3 way switch and 3 way dimmer switch Aurora65 Electrical 3 02-20-2013 08:08 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
