I Need Help With This Electrical Diagram - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-09-2013, 07:37 AM   #16
Rabidcapybara's Avatar
Rewards Points: 35
Thank you for the hint! One more question though. Would both wires from the 14/2 go to the brass screw of the luminare
Rabidcapybara is offline   Reply With Quote
Old 12-09-2013, 07:41 AM   #17
joed's Avatar
Rewards Points: 13,712
The hint will work but it is still not a code compliant way to do it.
NO both wire do not go to brass screw.
Old 12-09-2013, 07:50 AM   #18
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
IMHO trick question ....
here the "duplex is always hot" ,,,,,,,,,,LOL
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 12-09-2013, 08:04 AM   #19
Rewards Points: 35
Originally Posted by Philly Master
IMHO trick question .... here the "duplex is always hot" ,,,,,,,,,,LOL
both receptacles need to be hot at the same time
Old 12-09-2013, 08:05 AM   #20
Rewards Points: 35
I think i got it but wont know till tomorrow.
Old 12-09-2013, 08:11 AM   #21
Rewards Points: 516
well then friggin share it !!!!
Old 12-09-2013, 08:17 AM   #22
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
It is easy to do but I am not going to do your home work but I will give you some hints. Very easy for anyone familiar with "Knob & Tube" wiring.
The wiring method is a code violation and has been since the 1920's because it switches the neutral and in certain switch positions the shell of the light socket is hot.
Google " Carter 3 way switch".
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Philly Master (12-09-2013)
Old 12-09-2013, 08:24 AM   #23
Rewards Points: 516
I made that drawning but decided not to post it ..LOL
Old 12-09-2013, 08:51 AM   #24
Rewards Points: 35
ill share it if it works
Old 12-09-2013, 08:59 AM   #25
Rewards Points: 35
Originally Posted by rjniles
It is easy to do but I am not going to do your home work but I will give you some hints. Very easy for anyone familiar with "Knob & Tube" wiring. The wiring method is a code violation and has been since the 1920's because it switches the neutral and in certain switch positions the shell of the light socket is hot. Google " Carter 3 way switch".
ill post my diagram here if it works tomorrow
Old 12-09-2013, 09:10 AM   #26
Rewards Points: 516
that sucks ....after we try and help ....
Old 12-09-2013, 09:17 AM   #27
Rewards Points: 35
well i don't know if it works yet
Old 12-09-2013, 09:20 AM   #28
Rewards Points: 35
Take the hints they helped a lot! Thanx for them
Old 12-09-2013, 02:45 PM   #29
dmxtothemax's Avatar
Rewards Points: 5,604
The OP mentions a three way arrangement,
Some confusion here !
Does he mean like a three way light arrangement ?
If so he cannot have a recepticule
Without an extra wire.
Or does he mean a three way because there are three
items on the line ? switch,lamp,recepticule.
Whats going on ?
What does he currently have ?
And were is it located ?
dmxtothemax is offline   Reply With Quote
Old 12-09-2013, 02:46 PM   #30
joed's Avatar
If you post it we can tell you if it works or not.
It's the California three way not the Carter three way. If you look back over the last few weeks both diagrams have been posted. The Cali three way is not code compliant since it makes the shell of the lamp hold hot on some switch configurations.
The Following User Says Thank You to joed For This Useful Post:
Philly Master (12-10-2013)
Electrical diagram for 3 way switch and 3 way dimmer switch Aurora65 Electrical 3 02-20-2013 08:08 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
