I Need Help With This Electrical Diagram - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2013, 07:13 PM   #1
Rabidcapybara's Avatar
Rewards Points: 35
I need help with this electrical diagram
Can someone help or explain to me how you can add a receptacle after a 3 way circuit. Add a diagram please. And if someone can explain to me what a well pump receptacle is?
Rabidcapybara is offline   Reply With Quote
Old 12-08-2013, 10:07 PM   #2
Licensed electrician
Rewards Points: 1,892
The well pump receptacle would be where the pump to provide water to the house would plug in.
Old 12-08-2013, 10:18 PM   #3
Rewards Points: 35
Thanks. But any idea how to wire it?
Old 12-08-2013, 11:26 PM   #4
What is the voltage and ampacity required?
Old 12-08-2013, 11:39 PM   #5
Electrical Contractor
kbsparky's Avatar
Originally Posted by Rabidcapybara View Post
... any idea how to wire it?
Impossible to properly wire it using the materials shown.
Replace that piece of 14/3 between the switches with a piece of 14/4.
Then you might be able to make it work....
PROVIDED that the "well pump" motor is small enough to operate on a 15 Amp circuit, with the other loads present.
-KB
Old 12-08-2013, 11:40 PM   #6
Rewards Points: 35
120v not sure on amps
Old 12-08-2013, 11:41 PM   #7
Rewards Points: 35
14/2 and 14/3 cables only
Old 12-08-2013, 11:43 PM   #8
Rewards Points: 35
Originally Posted by kbsparky
Impossible to properly wire it using the materials shown. Replace that piece of 14/3 between the switches with a piece of 14/4. Then you might be able to make it work.... PROVIDED that the "well pump" motor is small enough to operate on a 15 Amp circuit, with the other loads present.
that is the only cable i have to keep 14/3
Old 12-09-2013, 12:16 AM   #9
220,221,whatever it takes
Rewards Points: 33
Are you sure you don't mean SUMP pump rather than well pump???? Most well pumps are 240v, and are hard-wired, while sump pumps are 120v, and are cord-and-plug.
Bernie Brewer is offline   Reply With Quote
Old 12-09-2013, 12:29 AM   #10
Rewards Points: 35
Yes i meant what i said. The diagram says Well pump receptacle. I know for a fact 120v
Old 12-09-2013, 06:02 AM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I need help with this diagram! Help!
Old 12-09-2013, 06:06 AM   #12
k_buz's Avatar
I know how to do it, but I'm not doing his homework for him.
Hint...think CA 3Way
The Following 2 Users Say Thank You to k_buz For This Useful Post:
jbfan (12-09-2013), Rabidcapybara (12-09-2013)
Old 12-09-2013, 06:31 AM   #13
jbfan's Avatar
Rewards Points: 650
My thoughts also K_buz.
Old 12-09-2013, 07:33 AM   #14
Rewards Points: 2,516
Had this diagram saved. Receptacle is always hot in this arrangement
hammerlane is offline   Reply With Quote
Old 12-09-2013, 07:37 AM   #15
joed's Avatar
Rewards Points: 13,752
This is s duplicate post
Hammerlane: The receptacle is at the wrong switch.
The Following User Says Thank You to joed For This Useful Post:
hammerlane (12-09-2013)
Electrical diagram for 3 way switch and 3 way dimmer switch Aurora65 Electrical 3 02-20-2013 08:08 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
