I Need Help With This Diagram! Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2013, 05:40 PM   #1
Rabidcapybara's Avatar
Rewards Points: 35
I need help with this diagram! Help!
I do not know how to keep a duplex receptacle hot after a 3 way circuit.
Rabidcapybara is offline   Reply With Quote
Old 12-08-2013, 05:41 PM   #2
Rewards Points: 35
Need this project done by tomorrow! Everyone please help!
Old 12-08-2013, 05:59 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You don't have the proper wiring to do what you want.
Old 12-08-2013, 06:09 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Run a 2 wire cable from the 3 way on the left of the diagram to the receptacle.
Coastal South Carolina
Old 12-08-2013, 06:12 PM   #5
k_buz's Avatar
It would be rare you could install a well pump on a 120V lighting circuit. I don't think I've ever seen a 120V well pump.
Old 12-08-2013, 06:22 PM   #6
Rewards Points: 35
You're right i never did. Im a student and this is my last project. My teacher said this is possible but he won't tell me how
Old 12-08-2013, 06:29 PM   #7
Licensed electrician
Rewards Points: 1,482
Possible and code compliance are not necessarily the same.
Old 12-08-2013, 06:38 PM   #8
Rewards Points: 35
can you draw a diagram or help me?
Old 12-08-2013, 07:11 PM   #9
joed's Avatar
Rewards Points: 12,412
You can not do with cable installed unless you illegally use the ground wire for a current carrier.
Old 12-08-2013, 07:15 PM   #10
Rewards Points: 35
my teacher said in all the years he's been teaching only 2-3 people have done it. I cannot use ground or neutrals as current carrying conductors.
Old 12-08-2013, 07:33 PM   #11
Rewards Points: 35
Anyone know if this can work?
Old 12-08-2013, 08:06 PM   #12
Rewards Points: 35
Receptacles
An receptacles care current through it if i don't brake the break off fin?
Old 12-08-2013, 08:09 PM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Either you are an ESL person or you are on a phone without spell check.
I assume you are asking if a receptacle can carry current through if the tab is not broken off.
Yes, like the millions of receptacles out there in use, the tab can carry the full current of the circuit if it is left in place.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Rabidcapybara (12-08-2013)
Old 12-08-2013, 08:13 PM   #14
Well he's wrong. He is trying to test you, or he has some non-complaint way of doing it.
Also, neutrals ARE current carrying conductors. They're just not "hot" conductors.
Reading Diagram on the Side of Fan Relay justplumducky HVAC 3 11-05-2013 07:24 AM
please check out this wiring diagram joregon3597 Electrical 8 07-07-2013 08:57 PM
Plumbing - DWV - Layout Diagram whozeawhat Plumbing 4 11-19-2010 09:07 PM
Plumbing Diagram Assistance bdaub Plumbing 9 05-26-2010 08:32 AM
wiring diagram question screenporch21 Electrical 10 11-30-2008 08:14 PM
