I Need Help - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2009, 09:56 PM   #1
i need help
i just bought my first house about 2 months ago.it has a single garage attached but it has no heat.
my wife bought me an electric portable heater but it just didnt have enough output to even take the chill off the garage.
so i returned that one and picked up another one that has a 240 volt 30 amp plug.i only took it because there is what i thought was a 240 volt receptacle already wired in the garage.
turns out it was a 220 volt (4 prong dryer receptacle) and a 40 amp double pole breaker in the panel.
the 220 volt receptacle is run using a 4 wire(1 red,1 black,1white and a bare ground).
the plug on the heater is a 3 prong plug.
i bought the proper receptacle to recieve the heater plug.
my question is this,how do i go about rewiring the new 3 prong receptacle?
fitter527 is offline   Reply With Quote
Old 12-10-2009, 10:04 PM   #2
joed's Avatar
Rewards Points: 13,288
Change the breaker to 30 amp. It must match the receptacle.
The receptacle gets wired using only the red, black and ground. Red and black go on the X and Y terminals. It doesn't matter which one goes where. Ground goes on the green. Cap the white wire and leave it in the box.
Old 12-10-2009, 10:09 PM   #3
thanx.i am going to replace the breaker but what would happen if i ran the 40 amp breaker?
Old 12-10-2009, 10:16 PM   #4
Probably nothing but you would not be code compliant.
hayewe farm is offline   Reply With Quote
Old 12-10-2009, 10:17 PM   #5
If it malfunctions or overheats worst case you could burn down the house
Old 12-10-2009, 10:25 PM   #6
im gonna replace the breaker, but i was just curious because i have very little electrical experience.
since im already here i have another question to ask.
i also have a jacuzzi tub that will not turn on.im not sure if its the pump?
where should i start with diagnosis?i was going to post in the plumbing but i dont think its anything to do with the plumbing.
Old 12-10-2009, 10:26 PM   #7
Like a bath tub or a big hot tub ?
Working up until now... ?
Just hooked up ?
Old 12-11-2009, 12:36 AM   #8
the 3 prong recepticle will take the red and black and green wires. wire cap the white and tuck it in the box in case you want to change it back. and put in a 30 amp breaker so you don't start any fires.
As far as the hot tub. get a meter and check for electricity at the pump....
smeric28 is offline   Reply With Quote
Old 12-11-2009, 09:42 AM   #9
joed's Avatar
Look for a GFCI to reset for the jacuzzi tub.
Old 12-11-2009, 10:15 AM   #10
Ya know on second thought. The Borg stores sell appliance cords, a premolded plug to a pigtail. i would buy one that matches the existing plug, and rewire the heater.
