I Need Help With A 3 Phase System. Please Help - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 08:18 AM   #1
I need help with a 3 Phase System. Please Help
Hello,
I have a tanning bed that requires 3 Phase to be connected. However I only have a 2 Phase outlet. I have 2 transformers that need to be connected they are
GE buck Boost Transformer Model 9T51B0110
GE buck Boost Transformer Model 9T51B0130
I am guessing the bed needs both connected to work. I included a schematic of what i have and what i need for output. Any help is appreciated on how i can connect this.
Thank you for all the help.
virgiltu is offline   Reply With Quote
Old 12-07-2009, 09:48 AM   #2
Licensed Pro
3 phase? 2 phase?
Best help I can offer is to hire an electrician. You are in way over your head here.
Old 12-07-2009, 10:05 AM   #3
The outlet is 2 phase and the bed will need 3 phase. The transformer wiring will determine the 3 phase output.
Old 12-07-2009, 10:09 AM   #4
What is a 2 phase outlet? Where are you located?
jerryh3 is offline   Reply With Quote
Old 12-07-2009, 10:15 AM   #5
Idiot Emeritus
Rewards Points: 1,492
If the two phase outlet is actually a 240 volt single phase outlet, a transformer will not make it 3 phase. The only ways to get 3 phase power from a single phase source are with a phase converter or a VFD.
If the outlet is at a house, it is almost certainly single phase.
Rob
micromind is offline   Reply With Quote
Old 12-07-2009, 10:23 AM   #6
Hello,
Thank you. This is actually set up at the tanning salon so they do have a 3 phase line, just not in that room. I will suggest to move the bed to another room or just pay an electrician to come and drop another line in that room. I was not sure about the transformer. I just thought i had it connected wrong. Thank you again.
Old 12-07-2009, 10:33 AM   #7
Idiot Emeritus
Very likely the power supply is a 120/208 3 phase system. If the bed needs 240, you'll need to connect the two transformers to boost the voltage.
Beware, a lot of electricians don't know how to connect buck-boost transformers.
Rob
Old 12-07-2009, 01:20 PM   #8
Yes that was my problem. I dont know how to connect them. So far i got them to give me 240v between the two black on the bed side and 120v between all the others. However since i dont have another phase the from white to black and from white to red i get 120v. I need 240. Thats y I posted the diagram of what i have and what I need. I figured I am wiring something wrong. Thank you
Old 12-07-2009, 03:14 PM   #9
Idiot Emeritus
If the power system is 120/208, you'll need all 3 phases, and two transformers. Here's how to connect it.
1) Transformer #1; H4 and X1 are connected to incoming phase A. H2 and H3 are connected together. X2 and X3 are connected together. H1 is connected to incoming phase B. X4 is outgoing phase A.
2) Transformer #2; H4 and X1 are connected to incoming phase C. H2 and H3 are connected together. X2 and X3 are connected together. H1 is connected to incoming phase B. X4 is outgoing phase C.
3) Incoming phase B is the same as outgoing phase B. It goes straight through, but both H1s are connected to it.
This will give about 28 volts boost. Any load involving the neutral must be connected to phase B. It's the only one that's still 120 to neutral.
If you'll post the VA or KVA ratings of the transformers, and the amp requirement of the bed, I (or one of the other guys around here) will tell you if they are big enough.
Rob
P.S. Is the black-red-white a cable of some sort that originates in the panel? If it is, and the white is landed on the neutral bus, simply move it to one pole of a 3 pole breaker, and you'll have all 3 phases. Label the white some other color, like blue.
Old 12-07-2009, 03:18 PM   #10
Hello,
I just checked and that is the way i have them installed. I guess the issues is that I dont have Phase B to go from H1 to H1 and to the bed. So I will check if i can move the bed to another room where I have a 3 phase installation.
Thank you so much for your help.
Old 12-07-2009, 03:21 PM   #11
Idiot Emeritus
Sorry, I'm a bit slow, check the P.S. I added.
Rob
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
new system install.....questions firedogut HVAC 4 10-04-2009 07:10 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
