I Need A 200amp Meter Socket Combo - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 09:45 AM   #1
I need a 200amp meter socket combo
Looking for suggestions on what brand 200amp meter socket combo to buy, it needs to have a main breaker and only 4+- circuits.
vtboy51 is offline   Reply With Quote
Old 04-05-2013, 11:31 AM   #2
Rewards Points: 58
Go to Home Depot and Lowes and check out what they have. Siemens, GE, Square D seem to be the most common and all are fine. Look for a copper bus.
Old 04-05-2013, 12:09 PM   #3
TTW
TTW's Avatar
You can also call your power company for a recommendation. Depending on where you are located requirements may vary. Please put your location in your profile. We don't even know if you are in the US or Canada!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 04-05-2013, 10:27 PM   #4
Electrical Contractor
kbsparky's Avatar
Look for a Homeline RC816F200CH combo box.
Home Depot has `em, and if not in stock at your loco store, you can order it and they will ship it to you for free.
-KB
Old 04-06-2013, 02:28 PM   #5
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Have you used any of the panels you have mentioned. I have been using the milbank units and I just noticed the homeline units you posted are $50 cheaper.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-06-2013, 06:08 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Around here, the poco has a list of meters that you can use.... so be sure to check that out.
Old 04-06-2013, 11:01 PM   #7
rrolleston's Avatar
Lucky thing around here it just has to be ringless. But a good idea for people to check their POCO.
Old 04-07-2013, 09:03 PM   #8
kbsparky's Avatar
Yes, we use them all the time.
Got several of them on hand in my shop right now. That way, I don't have to wait for them to ship it to me when we get a rush job.
Never had any problems with the Square D stuf
-KB
Old 04-08-2013, 07:29 AM   #9
Rewards Points: 3,130
Homeline is Square D's residential brand. Very good stuff; used it in my house.
Old 04-08-2013, 08:54 AM   #10
rrolleston's Avatar
Have you tried any of the milbank meter mains. They looks just like the milbank ones I buy over or underground feed and over or under for sub seed. I think I am going to give one a shot. There is a supply house that stocks Square D will have to also price them there.
Old 04-09-2013, 12:53 AM   #11
kbsparky's Avatar
Nope. Too much $$$. Can't be competitive with their stuff.
-KB
Old 04-09-2013, 01:21 AM   #12
" Euro " electrician
frenchelectrican's Avatar
The Milbank is not too bad for me but only one quirk is I have to watch the meter socket lugs make sure you do not overtoqure it. ( they can break without warning )
And the last part is make sure you watch the meter socket postion to make sure they are in correct postion if you get one of them off kinker you can overheat the lug behind the meter itself ( seems like smart meters are worst and it don't take much to smoke them )
The SqD is good one I have used them in both USA and France ( it will have different meter set up than what North Americain will be )
The costwise between the two is not that huge a spread but the key issue is I can able order a special socket quick so either way I can use them as long it approved per POCO specs.
Merci,
Marc
meter/main combo to load center grounds and bonding? ronsquery Electrical 2 03-16-2013 06:29 AM
meter socket Mule98 Electrical 7 09-24-2012 12:38 AM
Can the meter socket itself be replaced? Johnd85053 Electrical 19 02-14-2012 07:02 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
100amps meter with 200amp breaker box? Snooker Electrical 3 04-15-2007 02:39 PM
