I Mounted Switch Box Sideways - Can I Fix It? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 06:05 PM   #16
Rewards Points: 150
Originally Posted by wirenut1110 View Post
Also, don't forget to fill unused holes, I'm sure you don't want this
That may exceed box fill limits!
Gary
Gary_602z is offline   Reply With Quote
Old 02-06-2009, 07:19 PM   #17
Learning by Doing
Leah Frances's Avatar
Originally Posted by 220/221 View Post
Good god that is ugly.
It may work but......not much room for dimmers
If there is a next time, bring all the cables in the same side of the box. It eliminates a lot of crap.
A mud ring would have to be drilled and will probably make it stick out too far. Just take it apart and fix it. 10-20 minutes.
Ouch, I'd thought I'd done a pretty good job.I'm up for constructive criticism; how could I better run the four cables: two 12/2s and two 12/3s.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-06-2009, 07:29 PM   #18
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
It looks fine, especially the wire markers
wirenut1110 is offline   Reply With Quote
Old 02-06-2009, 07:47 PM   #19
dSilanskas's Avatar
It has a rat in its mouth its not burnt
dSilanskas is offline   Reply With Quote
Old 02-06-2009, 07:48 PM   #20
Rewards Points: 510
I'll be damned, I though his head was mutilated. Now that IS cool. Maybe he is still alive.
Old 02-06-2009, 08:09 PM   #21
dSilanskas's Avatar
i think it is still alive do you see the rat now?
Old 02-06-2009, 10:11 PM   #22
That looks like a 4/11 box instead of a 1900 box.
Come on. That's a two gang handy box. The tabs are positioned for devices.
First, run all cables into the top of the box.
Cut the wires so they come to the bottom of the box and bend back once to the top.
Wirenut the grounds with one wirenut leaving the appropriate pigtails and fold/tuck them way back in. Same with the neutrals. Same with other wires. When you leave too much wire in and have to fold it over twice it takes up valuable real estate.
Here is a pic with 2, 14/3's and 4, 14/2's many wires in it but still has a bunch of room in it for dimmers.
220/221 is offline   Reply With Quote
Old 02-06-2009, 10:31 PM   #23
Learning by Doing
Thanks for the pic. It's hard for us Noobs to visualize some of this stuff. It's nice to see it when it's done right. Pictures really help.
I think my biggest problem is being afraid of not leaving enough wire so I end up with too much slack that has to be crammed back inside. After some more experience, I would never do the grounds the same way as that box.
Plus, despite alot of practice, I really suck at twisting four or more 12s together. In all honestly, I think it's cause I'm a girl. Really. I've got a set of high quality linesman pliers - my problem is that I lack the hand strength in my left hand to keep the wires lined up while I twist with the pliers in my right hand. I always seem to end up with one wire that creeps as I twist and ends up coiled around the others, resulting in a big-ole-mess.
My electrical mentor (good ol'Dad) says that's why he likes 15 A circuits - 14 gauge wire.
Dimmer Switch Vandiyan Electrical 21 12-15-2008 07:23 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
