Old 02-06-2009, 05:05 PM   #1
Learning by Doing
Leah Frances's Avatar
I mounted switch box sideways - can I fix it?
When I went to wire in my switches to test my two new AFCI protected () circuits I discovered this problem:
I'm going to call it a newbie mistake - but it was also a failure to pay attention to the details.
I want to mount the switches vertically - is there a cheat around this problem?
BTW: everything WORKS!!!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-06-2009, 05:31 PM   #2
dSilanskas's Avatar
Yes just get a plaster ring
dSilanskas is offline   Reply With Quote
Old 02-06-2009, 05:35 PM   #3
Take the box out and turn it.
jerryh3 is offline   Reply With Quote
Old 02-06-2009, 05:37 PM   #4
dSilanskas's Avatar
Than get a plaster ring! hahaha
Old 02-06-2009, 05:41 PM   #5
Learning by Doing
Plaster ring it is! Thanks for a simple solution.
Old 02-06-2009, 05:42 PM   #6
Good god that is ugly.
It may work but......not much room for dimmers
If there is a next time, bring all the cables in the same side of the box. It eliminates a lot of crap.
A mud ring would have to be drilled and will probably make it stick out too far. Just take it apart and fix it. 10-20 minutes.
220/221 is offline   Reply With Quote
Old 02-06-2009, 05:48 PM   #7
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
I'm not sure a plaster ring will work for that box. All the one's I've seen the screws are in the corners.
wirenut1110 is offline   Reply With Quote
Old 02-06-2009, 05:56 PM   #8
Also, don't forget to fill unused holes, I'm sure you don't want this
Old 02-06-2009, 06:35 PM   #9
dSilanskas's Avatar
HOLLY IS THAT SNAKE STILL ALIVE??!?!?!
Old 02-06-2009, 06:45 PM   #10
No,I have another pic that showed it after they pull it out and his little head looks fried
Old 02-06-2009, 06:49 PM   #11
dSilanskas's Avatar
Do post
Old 02-06-2009, 06:54 PM   #12
joed's Avatar
The drywall is not installed. It is a 5 minute job to take off and replace with another one or turn it.
Old 02-06-2009, 06:55 PM   #13
That looks like a 4/11 box instead of a 1900 box.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 02-06-2009, 06:56 PM   #14
Here ya go just glad it wasn't me
Old 02-06-2009, 07:04 PM   #15
At least you could see it before you opened the door!
Dimmer Switch Vandiyan Electrical 21 12-15-2008 08:23 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
