I Have To Keep Hitting Breaker Switch! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 07:59 PM   #1
I have to keep hitting breaker switch!
Hello everyone, wanted to know if anyone could tell me why I could possibly have to keep resetting my breaker to get my dryer to work. The crazy thing is that the dryer will still turn and stay on but it will not heat up. Switched the dryer out for different dryer because at first thought it was that, same thing.. Any advise is appreciated.
Roofing Project is offline   Reply With Quote
Old 03-16-2012, 08:37 PM   #2
Rewards Points: 14,014
Undersized wires or a loose connection someplace can cause an over heat and a trip.
The motor only needs 110 volts to run, you need 220 volts for the heat to work.
This is a double pole breaker right? How many amps. is it.
plummen (03-16-2012)
Old 03-16-2012, 09:06 PM   #3
Licensed electrician
Rewards Points: 1,772
Are you having any problems in the rest of the house? Sounds like you have lost one leg to the dryer and are only getting 120, not the 240 you need for the heat.
Old 03-16-2012, 09:19 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
It is possible that you have killed the breaker before changing dryers!
Old 03-16-2012, 09:53 PM   #5
I do have a couple outlets in my daughters that get no power and my living room light does dim every so often...but that has all been like that the 2yrs we have been here...No other major issues and this dryer thing just started maybe 2 mnths ago
Old 03-16-2012, 11:20 PM   #6
None of that sounds good.
Loose wires and under sized wiring causes fires.
Old 03-17-2012, 12:13 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,506
Can you safely measure the line voltage,
before and after you turn on the heating element ?
And does the dryer need 220v or is it only 120v ?
Could be many things,
so you have to follow a proceedure
to find the fault.
Start by checking the voltage as i suggested,
If you dont feel confident to do it !
then dont, let a pro fix it.
dmxtothemax is online now   Reply With Quote
Tags
breaker tripping , dryer , electrical box
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Light Switch Breaker Trip kremic30 Electrical 11 02-17-2012 06:55 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Generator Safety Switch Help - Breaker Size? limey_swindon Electrical 3 01-09-2008 11:40 AM
