I Have A House With Aluminum Wiring Should I Pigtail Every Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 05:33 PM   #16
Rewards Points: 39
Why does the type of metal used in the wire make such a difference as to how things are done?
Typ0 is offline   Reply With Quote
Old 01-28-2009, 05:35 PM   #17
Rewards Points: 2,350
Originally Posted by Chemist1961 View Post
Gigs,
Not to steal the post. I have Federal Pioneer Stablok and AL approx 32 years old. Is there an issue with this combo. "Is your panel Federal Pacific Stab-lok by any chance?"
I have changed all connectors to AL rtaed and used paste.
No, the Federal Pioneer panels, while related, never had the problems the Federal Pacific had. And... and... to others reading, it was only the later models of Federal Pacific that had the problems.
Old 01-28-2009, 05:38 PM   #18
Because aluminum likes to oxidize when exposed to air, especially when in contact with another type of metal, like copper. This oxidation is not a good conductor and a bad connection forms. Bad connection = heat. Heat = fire.
Also, aluminum is pretty brittle is such small sizes, so if not handled and stripped properly, you can end up with a broken or nicked wire.
Old 01-28-2009, 05:46 PM   #19
DIYer
Gigs,
Federal Pacific Stab-lok is often recommended to be replaced entirely, whether copper or Al because the breakers often fail to trip causing a latent fire hazard.
Like InPhase said you are probably ok since it's just federal pacific with the issue.
Gigs is offline   Reply With Quote
Old 01-28-2009, 07:07 PM   #20
Good, to know. Either way I try to keep up on this info. Mine's been fully inspected as well.
Chemist1961 is offline   Reply With Quote
Old Wiring, New Outlet atkearns Electrical 9 11-23-2008 12:33 PM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 06:25 PM
60 year old house wiring bigp58 Electrical 1 04-21-2008 11:32 AM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 08:38 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
